>My mechanic pulled a fast one on me. Installed drivers upper control arm
>bushing then told me he did not have time to do the alignment.
>Where is the procedure for the infamous string alignment and can I use
>it to set Caster and Camber?
>HELP!
>Ron and Julie
Ron - the string method is on Gene Fisher's site
I don't think that you can do the caster and camber with this method.
I just replaced a torn CV boot last week and found that the front
upper arm bolt was worn and the upper arm could move in and out about
1/8". I removed the arm and went to AutoZone and found new Tornado
bushings for about $7 each. I brought them to a machine shop which
had a press and they took out the old ones and pressed in the new
ones for $14. I could not find a cam bolt for the upper control arm.
GM said the part number is no longer valid (discontinued about 10
years ago) and none of the auto parts shops or alignment shops had
one, so I bought a 1/2" x 20 thread grade 8 bolt and carefully
ground down a flat along its length so that it would fit the two
cams. Its back together but now I've got to find a shop that will
check the camber and caster. There are good instructions in the
Maintenance manual but I believe that you've got to have the machine
to do it. One alignment shop wouldn't do it because they said to do
it properly it should be put onto a rack and the GMC was too long for
theirs. I'm looking for someplace to do it right now.
Santa Fe, NM
