Got a new UV light, ran the rig at idle/fast idle plus until operating temp
was reached. Ran it for 10 minutes, shut it off to let it heatsoak, ran it
for a while longer.
No traces of leak, but I know it does.
Ran this without fan so as not to blow oil around.
Guess it needs a real run. Thinking of options: 1) run in place longer and
perhaps higher rpm, 2) go for a real run around the block or so. I'd still
leave the fan off (have 2 electric radiator fans in case needed for cooling)
so that oil doesn't swirl around.
Any thoughts on this or better ideas/suggestions?
TIA - Heinz
for a while longer.
TIA - Heinz
