Where did you get a silicone boot? The boot, upper and lower I put on my
coach turned to dust. Dirtiest job I ever did.
> OK I got the blue silicone boot, looks food so far for the upper CV joint.
> OK here's the $64.00 question - when I separate the CV joint assembly from
> the upper column, do I undo the pinch bolt and slip it off the small
> splines or do I undo the series of bolts around the top of the joint?
> Also (this may not work) after reading tales of woe from other owners who
> have struggled to remove the blue splines from the lower U joint, it seems
> to me that well greased components would have a great deal of suction
> happening that would prevent the blue spline from withdrawing. Now if the
> zirk
> were removed before trying to separate the parts, air could enter through
> the now open grease port and relieve the suction effect.
> TIA
> Larry
> Larry - Victoria BC -
> 1977 Palm Beach VIN TZE167V101295 - 39,000 miles, PO said everything
> working but forgot the word NOT. New wiper blades, New SS exhaust system ..
*Len and Pat Novak*
*1978 GMC Kingsley*
*The Beast II with dash lights that work and labels you can see!*
*Las Vegas, NV* new email: B52sRule
http://www.gmcmhphotos.com/photos/showgallery.php?cat=4375
www.bdub.net/novak/
