Steering Gear / Caspro unit.
heinz wittenbecher
1,470
Sorry to take so long Arch. Too many things to do (play with :-)
The Caspro price is $535, so your friend may not have gotten stuck, if it
was a Caspro or equivilant unit.
I'm quite happy to pay the Caspro price based on past experience with
Caspro, as in no complaints. The steering box I'm replacing is also a Caspro
and has served me well for 10 years plus. That one was represented and sold
as a rebuild as at the time no new was available.
Of course I have no proof that what I have now is indeed a NEW unit, other
than to take the salesman's word for it, but what the hell... gotta trust
'em sometimes :-)
> I had to tip my head to the left to read it. There's a number cast into
the
> iron portion on the front of the box assembly: 7802644L.
Cast number is the same, which is not surprising as I would think the
"shell" would be same for all.
>Just below it is
> the number 27.
Mine has a 26.
> There is also a small number that was so poorly cast, I
> couldn't read it. It was to the right of the 27, right being higher when
> looking at the box with my head twisted left, eyeballs on a vertical
plane.
> There is a bright metal (looks like aluminum) cover plate, with a number
cast
> into the metal: 7812145.
same.
>On a flat surface on the plate, a number is
> stamped: 304A7 (the 30 part was hard to read, so it may not be correct)
> On the cover plate, and on the bottom seal (aluminum again?) there was a
> white sticker on each with the letters "CM" in bold black letters.
Yup, mine too.
Unfortunately the barcoded partnumber got rubbed off during shipping.
I won't be installing it until after my next trip so we'll have to wait a
little longer to see if there is much diff from old to new.
Hope this helps
Heinz
'76 Transmode
www.bytedesigns.com/gmc
Forgot to mention... the Caspro unit came with an external PS fluid filter
(AC Delco). If I recall they are not exactly cheap. I bought one from the
local GM and if I recall correctly they were over $50.... and then I never
did install it :-)
I think I will install this one though when doing the new steering box and
shaft.
Heinz
As I said earlier... not surprised that casting numbers are all the same.
I think the same phenomena exists with Master Cylinders. I for one have
learned my lesson in that corner and will stick to MC's from Cinnebar in
future unless I stray from stock MC altogether :-)
Heinz
number
> > cast
> > same.
correct)
was a
> Heinz
> Thanks! Looks like our unknown unit is a Caspro. Has any one else look at
> their steering gear????? What kind of number do you have??? Heinz the
> real kicker here is that the known NAPA unit has the same 7812144 #
> as you do. The only difference between the known Caspro the unknown
> unit and the NAPA unit is the L at the end of the 7802644 # The cover
> plate number is the same. Emery what does this mean???
> Take Care
> Arch
