http://www.california.com/~eagle/steering.htm Bert and Fay;
Go here and you will find what you are looking for. I did the change
after trying to do the adjustment bit and replacing other suspect
pieces. Biggest improvement I made.
Bill
> Has anyone used a NAPA rebuilt steering box and if so, what is the
> part
> number? Is it internally the same as the original GMC one? If not,
> do you
> think it is better or worse feeling in your opinion - i.e. would you
> do it
> again? Ours is worn out, probably because the sliding shaft stop
> sliding
> sometime in the distant past before we purchased the coach. At the
> moment a
> rudder at the back of the coach would have more effect than the
> steering
> wheel .
> Thanks in advance
> Bert and Fay Curtis
> '76 Glenbrook
Bill
> part
> do you
> do it
> sliding
> moment a
> steering
> wheel .
> Thanks in advance
> Bert and Fay Curtis
> '76 Glenbrook
