- -snip-
>IMHO I would not do that. Put the charger in the cabinet--no problem.
>#6 will do just fine. Everything I have seen says to keep the cable run
>to the inverter as short as possible. Some sort of noise ect.
One of the main reasoins to keep the inverter close to the batteries is
that the wires betweent he batteries and inverter will have some voltage
drop. When your inverter draws a large current there will be DC
inefficiencies that are directly proportional to the line drop. Short lines
means less voltage drop. Bigger conductors also mean less drop.
Some inverters may also generate a very high frequency field in the DC
conductors. You may be able to reduce this by installing big capacitors
capable of handling the currents. (I wouldn't do it though)
- -snip-
>> I'm just planning on running the TVs and VCR with the inverter. I don't
>> plan on
>> using the microwave, coffee maker or toaster while on inverter
>> power. I guess I could, but I don't think the batteries could take it
for
>> long.
>> Any comments would be appreciated.
IF you only want to run the TV and VCR, you're better off using the DC
appliances from an energy usage standpoint. There's no inverter losses and
no losses converting AC to DC in the TV (although there may well be a DC-DC
converter instead depending on the model).
Of course, the AC versions of most appliances are cheaper.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
- -snip-
>> plan on
for
>> long.
Henry
fax: (831) 462-5198
