starting the engine
Kelly, pull your head out. It is not that complex. Under that plastic cover
with the 3 screws, is a flat wound spring with a square bend on the end. It
meshes with a piece of linkage connected to the choke plate internally in
the carb. That is why you could not detect any linkage. When the engine is
completely cold, loosen those three screws, (no need to remove them
completely), and rotate the plastic cover until you see the choke plate
move towards the closed position. If it opens, you are turning it the wrong
way. Turn towards the closed position until it just touches closed, then
tighten the screws. It is not a complicated adjustment. You can easily do
it. Your engine will thank you.
Salem, Or
78 GMC ROYALE 403
> Thank you Johnny, it also initially seemed to me like something was
> supposed to be connected but wasn't. Interesting comment on the right
> carb. I'll
> try to look that up. the three screws on the round black thing are on the
> passenger side where the bimetal spring is (that's the spring people are
> talking about not the visible spring?)
> Just making sure i have the right parts in mind
> kelly
> > After watching, I wonder if the spring is properly connected. (I also
> wonder if that's the correct carb - have you checked the number
> > stamped/cast on the driver's side of the carb against the manual?)
> > Remove the three screws on the round black thing and pull it out - it is
> the temp spring which moved the choke plate. You should see in its
> > housing a metal tab which is connected directly to the choke plate:
> Moving the tab should move the plate without any slack or hesitation. There
> > should be a slot in the tab which ebngages the end of the spring to move
> the choke. If this is broken or not properly engaged, the choke will not
> > work properly. When it is properly engaged, rotating the spring holder
> should also move the choke in either direction. When it does, turn it until
> > thye choke just closes and then replace and tighten the three screws.
> You choke stove looks properl;y installed and should work. Your unloader
> > diaphragm also looks properly hooked.
> > --johnny
> 1978 Kingsley
> Putney VT
Kelly,
Should you be at the International Convention in Indiana next month, I can
grab a old carb and explain all the pats and how it works.
I was fortunate to have been playing with this style carbs from 1960 .
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> > carb. I'll
> the
> > kelly
> is
> There
> move
> until
> > > --johnny
> > 1978 Kingsley
> > Putney VT
http://www.appliedgmc.com
I'll do this tonight!
thanks again all. I won't be at the convention, some year I hope to make it.
I've been so happy with my GMC, I'm a year+ in and can't help but smile when I drive it, and it is the best party bus you could want at one of our
festivals
I'll report back tonight what I find
-kelly
1978 Kingsley
Putney VT
it was as easy as you all said! :d
I removed the three screws, pushed the pedal down, rotated it (a lot) until the plate closed, put the screws back (could have just loosened them), put
it back together and it started instantly!
How do I know i didn't turn it too far? I let it idle high for awhile then tapped the gas and the RPMS dropped
Thanks all! I realize this isn't rocket science and I appreciate your patience!
kelly
1978 Kingsley
Putney VT
Kelly, look for signs of black smoke out the exhaust after the engine is at
operating temperature. And, the choke plate should be vertical. If black
smoke is what you see, make a very slight adjustment to the open direction,
and try again.
Good job by the way.
Salem, Or
78 GMC ROYALE 403
> them), put
> patience!
> kelly
> 1978 Kingsley
> Putney VT
The door buzzer can be defeated by pulling the ignition key out a little
bit. It is part of a necessary relay, but there is a replacement relay that
does not have the buzzer. Call Jim K. He will stock it.
Salem, Or
78 GMC ROYALE 403
> Just what I was looking for, something obvious.
> I'll go start it again and wait
> By the way, can I just reach in and remove whatever buzzes for the door
> alarm? it's annoying
> Not sure this link works, it's a video of the GMC starting instantly
> https://www.facebook.com/groups/classicgmcmotorhomes/#
> thank you
> kelly
> 1978 Kingsley
> Putney VT
It seemed like dark smoke, so I opened it up, the choke was still slightly closed. I rotated to open it started it again.
now white smoke. I can't remember if it smoked like this before. Course there's probably extra gas/etc in there. I should take it for a drive
(unfortunately getting in/out of the driveway is the worst part of any trip...)
White smoke is OK? Water?
kelly
1978 Kingsley
Putney VT
Noise is from the fuse box, I shook it and it stopped. But yeah, I should get that. The plunger to tell me the door is open/closed is broken so it
randomly shows open. I should just remove the relay. Is it on the top of the fuse box or was I just lucky?
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> > thank you
> > kelly
> > 1978 Kingsley
> > Putney VT
1978 Kingsley
Putney VT
the nylon gasket that was in the carb filter is twisted and warped
no auto place has one (I did get two filters). Where do we get these? Can I put this one back in?
This is what the spring goes against.
1978 Kingsley
Putney VT
I believe this is the gasket that seals the filter housing to carburetor. I got some at local NAPA.
C. Boyd
76 Crestmont
East Tennessee
found them online for 35 cents each.
I ordered 10.
I put the original back in, no leaks that I can see/smell. Fingers crossed
-kelly
1978 Kingsley
Putney VT
Just want you to know I laugh every time i reread my post and stop here in your note and add my own last words (you had a period) :)
1978 Kingsley
Putney VT
Kelly, 'twas all done in fun. I figured if you bought a GMC MOTORHOME, you
certainly must (like me and many others here) have a twisted sense of
humor. I meant you no disrespect, that was just a gentle prod meant to
encourage you to action. Now you know, through firsthand experience, that
setting the automatic choke is a fairly straightforward process. You can do
it. I have confidence in you.
Welcome to the wild, wacky, world of gmc's.
Salem, Or
78 GMC ROYALE 403
> your head out
> 1978 Kingsley
> Putney VT
No offense taken at all! And since I was able to do that I went ahead and changed the carb filter.
Today I'm changing a steering wheel and cleaning the fridge burner.
Salem, Or
78 GMC ROYALE 403
> Kelly, pull
> > your head out
> > 1978 Kingsley
> > Putney VT
1978 Kingsley
Putney VT
