Yes Both tanks have fuel socks.
JRW
> Too soon to tell. I switched over from
> the AUX to the main. Its running right
> now. Have to wait for awhile to see.
> is there a fuel sock on both tanks?
> Rob Teed 74 Painted Desert
> > -----Original Message-----
> > From: owner-gmcmotorhome
> > [mailto
wner-gmcmotorhome]On Behalf Of John Wright
> > Sent: Saturday, April 10, 1999 6:49 PM
> > To: gmcmotorhome
> > Subject: Re: GMC: Stalling out
> > Rob,
> > Does it stall on both tanks or just one. If is quitting only on the
> > main tank I would suggest that the fuel sock in the gas tank is plugged.
> > If it is stalling on both tanks I would lean towards the fuel pump
> > diaphragm failed. Have you checked to see if there is a filter in the
> > fuel line before the fuel pump? Is the carb out of gas? Right after it
> > stalls look down the carb throat and press the gas peddle to the floor
> > and see if the accelerator pump adds fuel.
> > J.R. Wright
> > 77 Eleganza II
> > GMC GreatLaker
> > Midland, Mi
> > > Hi Everyone,
> > > I got the beast running, Then stalled
> > > out. Either the fuel pump or maybe
> > > a filter in the gas tank? The filter
> > > at the carb is new. It seems that if
> > > I let it sit for awhile it will start
> > > and run for awhile, 15 min or so...
> > > Any Ideas?
> > > Thanks,
