Gary,
Wow, with all that info I should be able to find what I need for The Blue Streak here in Aus and Double Trouble in the USA, no
worries!
Thanks,
From: gmclist-bounces [mailto:gmclist-bounces] On Behalf Of Gary Worobec
Sent: Thursday, 12 January 2012 12:35 PM
Subject: Re: [GMCnet] stainless steel belt line ??
Hey Rob,
1) Just a regular 1/4" radius 2 flute carbide cutter on a 3 hp router. I did
have to use a flap wheel to get rid of some of the cutter marks but no big
deal.
2) I have a router table where the router is mounted under the table and the
cutter sticks through. Then you set up a fence to keep the aluminum steady,
Not different than cutting wood. But wear safety glasses.
3). Yes, I actually used flathead 1/4" x 20 SS bolts and used aluminum
nutserts in all the old holes. I only sealed the top edge of the trim
because that way any water that does somehow get in there will run out the
bottom. Nutserts from
http://www.hansonrivet.com/ in L.A. They have got all
sizes and the 1/4" tool to install them.
The trim is from
http://tinyurl.com/89o8fs8 . I think I used the C600.
There are two cute gals who own the place that can help. It comes in all
colors. I used 7/8" wide as the counterbore for a 1/4" 20 flathead is 3/4 in
diameter.
I got the aluminum from
http://tinyurl.com/7qfwx7d. These are my favorite
metal guys. I used to buy from a metal recycle place but they would never
cut anything and I have all sorts of extra pieces lying around. IMS will cut
to size free so no waste.
Hope this helps.
Thanks
Gary and Joanne Worobec
1973 GMC Glacier
Anza, CA
----- Original Message -----
To:
Sent: Wednesday, January 11, 2012 5:15 PM
Gary,
That is the best looking belt line trim job I have ever seen on a GMC! It's
so nice I'm going to steal it!
Your '73 Glacier used the same belt line extrusion as my '75 Avion. I've
removed the OEM trim and found that there are lot of places
where water could be leaking in.
Some questions:
1) What kind of router blade did you use to achieve that nice radius?
2) How did you hold a 20' (+) x 2" piece of aluminum strip down to radius
it?
3) I assume there are screws under the blue trim strip did you use a sealer
between the strip & the coach?
Any additional tips greatly appreciated!
Rob M
Hi, Not stainless but used the same size in aluminum. Rounded the edges with
a router then had them powder coated in silver to match the rest of the
beltline front and back. Applied a 7/8" rub strip in blue to cover the bolt
holes. Stainless would be a b**ch to work with on something like this. Lots
of holes to drill and the polishing would be tough unless it came
pre-polished which would cost you a fortune.
Here is a picture.
http://tinyurl.com/6vsxr9v
Thanks
http://temp.gmcnet.org/cgi-bin/mailman/listinfo/gmclist
