My a/c squeaks pretty bad when I turn it on. The belts are not even a year old so I don't think that's an issue. Is there an easy way to tighten these
for a novice or is it best to take it to someone?
1978 Kingsley -
Kansas City, MO
Andrew the AC belt is particularly hard to tension. Several venders have tightening devices that work well. Search the GMC forum. Several years ago someone posed a fairly easy one to make yourself which I did and it works great.
Gene Fisher has some great info on belts to use and simple gauge to check tightness.
It takes about a minute if you have 2 people and a crow bar.
Loosen the top 2 pivot bolts, then go underneath and loosen the tension bolt (the one on the slotted tensioner) and then the person up top use the
crow bar to wedge against the bracket to tension, then underneath you tighten the tensioner bolt.
Tighten up the pivot bolts up top and you're done.
5 minute job at most,and that includes finding the bolts.
> Justin Brady
> http://www.thegmcrv.com/
> 1976 Palm Beach 455
------- http://bdub.net/gmcmotorhome.info/
Alternator Protection Cable http://bdub.net/gmcmotorhome.info/APC.html
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
