Emery:
I've been using nylock nuts on the grill studs and have not experienced
looseness since. I make sure that I don't torque down the nuts so that they
don't break the grill flange. To me, the springs are a Rude Goldberg way to
do it and they intrude into the space behind the grill. Of course, to each
his own.
Paul Bartz
Sent: Wednesday, August 18, 1999 3:54 PM
Subject: GMC: Spring mount for Grill
Patrick had suggested the use of springs for the GMC grille instead of the
bolts that are constantly shifting and coming loose.
I found that many home centers have a display board of springs. Number 190
which is 3/8"OD and about 6-1/4" long works well. I drilled a 1/8" hole in
the bottom opening lip on each side. 6-1/2" from the edge of the opening.
The same thing was done to the lip at the top of the top opening. Using
small "S" hooks at each end of the springs, one end going into the holes
drilled into the grill and the other hooking on the radiator supports. For
example the top left one (looking at the radiator from the front) hooks just
behind the radiator cap. When stretched, the springs are about 15 to 17
inches in length. I then black spray painted the S hooks that were hooked
into the grille so that they would not show.
I did this modification prior to going to Calif and can report that it held
my grille in place with no problems. I used to have to loosen and retighten
the lock nuts after a trip because the grille would shift. This
modification
also allows one to very quickly remove the grille to clean the radiator,
etc.
Emery Stora
his own.
Paul Bartz
modification
etc.
Emery Stora
