Jim,
Yes I did cross the speakers because of your earlier
posts to the GMCnet. It really does seem to improve the
sound quality.
Years ago I seem to recall that GM crossed the speakers in
their cars. At least I seem to remember reading that in the
owner's manual of a GM car from way back in the 70's.
Thanks for the help,
> Did you cross the outputs on the ceiling speakers? This will really help
> your imaging.
> I think the placemant of the 4x10's in the back is why they sound OK.
> Standing in the back, you are in the focal point of them near ear level.
> Let me know if I can help further,
> Jim Bounds
> >Jim,
> >The speaker installation is complete. This is what I did:
> >Bought Kenwood KFC-1676 6.5" speakers with a surface mount depth
> >of 1.75" (I said 1 5/8" before). I figured that with the new headliner
> >(1/8" Laun plywood with about 1/8" of fuzzy stuff glued to it)
> >the speaker has more then 1/8" clearance. By the way I had to
> >remove all the insulation to make room for the speaker magnets.
> >I didn't have to use spacers.
> >To mount the speakers I installed pieces of 1/4" plywood (the width
> >of the bays on each side aft of the plastic cockpit headliner. The
> >plywood is attached to the roof (rafter?) with 3/4" x 3/4" aluminum
> >angle iron. I used pop rivits to attach everything. The plywood is
> >flush to the roof rafters.
> >The plywood I think acts as a baffle. I stuffed some insulation
> >behind the plywood to help the sound. The speakers sound good
> >(my 2 sons, who know speakers like most teenagers, said they sound
> >pretty cool).
> >I connected the the 2 OEM speakers to my Cobra Compact Remote Mount
> >CB. That way I can listen to the CB and the radio.
> >I have a Kenwood 10 CD changer mounted in the locker over the dinette.
> >I can control the CD changer from the Kenwood radio I installed.
> >The speakers in the back are from Radio Shack as you have suggested
> >in the past. The PO had already installed them I added some fiberglass
> >insulation behind them because they used to rattle when the sound
> >is turned up (my sons).
> >I'm going to use a FM Modulator to allow me to pipe in the sound
> >from the new DVD player to the sound system. I have not done that
> >yet.
> >So far the speaker grills have stayed up. They snap on with a twist.
> >If
> >they fall off I guess I'll glue them up or something. I painted the
> >grills
> >with the same stuff I painted all the plastic parts. They look like
> >they
> >came from the factory white. They were black.
> >> Richard,
> >> If you are like me, I've got many more things to worry about than to stay
> >> up nights thinking about falling speaker grills! It stinks but there are
> >> very few speakers that have screw on grills anymore.
> >> I installed a set of Blaupunkt speakers that used little butyl rubber gobbs
> >> to hold on the metal mesh grills, they fell off in a couple of days! If
> >> the snap on grills are fastened properly, they have a slot where the
> >> indention goes that will hold them on well.
> >> While we're on the subject, I have put and do like the sound from speakers
> >> in the headliner but you must be sure you use a "thin mount" speaker
> >> because spacers I have seen people make because they did not consider the
> >> depth issue really look bad not to mention make a nasty scar on your
> >> forehead when you bump into them.
> >> Another issue is you must secure any speaker to a rigid opening that acts
> >> as a baffle board to enhanse the sound quality. Any speaker will sound bad
> >> if you operate it in open air "without a baffle board or enclosure".
> >> I found it much easier to recomend installing the speakers under the
> >> overhead cabinets as opposed to getting into all of this, so I applaude
> >> anyone that can properly mount a pair of speakers in the headliner. Good
> >> show old bean!!!
> >> Jim Bounds
> Jim Bounds/Co-op Motor Works Orlando
www.gmccoop.com
