I have used .060" gap from the
beginning.We already have impossible heating
conditions under the hood and the higher voltage in the wores caused by the
.080 gap makes things even worse for the ignition circuits.
>FWIW:
>I've used the .80 since day 1 some 200+k ago. Though I have changed cap 2 or
>3 times and am probably on 3 set of wires, the changes were always as PM,
>not breakdown. Last wire and cap change was in conjunction with change to
>ported EFI.
>Anyone else running other than .80? Comments? Observations pre/post change
>from .80?
>TIA - Heinz
>'76 Transmode
>-----Original Message-----
>From: RickStapls
>To: gmcmotorhome
>Date: Sunday, December 13, 1998 8:27 PM
>Subject: Re: GMC: Spark Plug Gap
>>> What is the correct spark plug gag for a 455 HEI engine?
>>.060", NOT the .080 listed in the original manuals. This is one case where
>>RTFM will get you in trouble, as the .080 gap raises voltage so high it
>burns
>>holes in the distributor rotor, arcs down the cap on a damp day, and eats
>plug
>>wires, even the $100 ones.
>>That's what I've heard.
>>Rick Staples
>>'75 Eleganza
>>Louisville, CO
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
