source for Thorley Headers
thom hole
212
Does anyone know of a mail order source for the THORLEY (?) headers that I
have been reading all about?? I need to rework the exhaust system fron
Cylinder heads to bumper. Also looking for source for Stainless y-pipes and
other parts neccessary. I have just subscribed to GMCMM and Cinnabar's
newsletter, so I don't have any back issues for researching the Ads. Thx.....th
Thom Hole
Here is the information you requesyted. I bought from them last week
headers arrived in 5 days. hope this helps.
Webb address is: "PRO-MAX PERFORMANCE"
Thomas,
>Thank you for your inquiry. If your motorhome is a Olds class A front
>wheel drive with a 455 olds motor, Doug Thorley does carry a set for you.
>Cost is $315.00 plus $22.00 for shipping. If we are not talking about the
>right type please e-mail us back with more information. Let us know if we
>can help.
>Pete
>-----Original Message-----
>From: Thomas Warner
>Date: Monday, March 23, 1998 9:52 PM
>Subject: Web Requested Information
>>Here's an inquiry from the web site.
>>Areas of interest:
>> Performance Exhaust
>>Comments and/or Questions:
>>price on doug thorley headers for 1976 GMC motorhome plus shipping
>>to NY
>>Address:
>>3692 Hogan road
>>Vernon Center, NY, 13477
>>Phone: 315-829-3398
>>FAX:
>>Email: warner
Thx.....th
>Thom Hole
>Cisco Systems Inc.
If you are doing Thorely Headers you might want to go the extra step and
have them ceramic coated. This can be done by Jet-Hott and a number of
other companies. It keeps the radiated heat way down and is worth the
extra $$. If you want to go that route you need to get the headers
with out the chrome plating. I know Thorely makes them that way and
that Pro_max should be able to provide them.
Marcus
> Thomas,
> >can help.
> >Pete
> >From: Thomas Warner
> >>Areas of interest:
> >> Performance Exhaust
> >>to NY
> >>Address:
> >>3692 Hogan road
> >>Phone: 315-829-3398
> >>FAX:
> >>Email: warner
> Thx.....th
>From everyone that I have talked to they advise against having the headers
coated. The reason that they run hot is that there is to much backpressure,
same reason that the original cast iron headers warp. Put the money into a
3 inch y pipe and tailpipe and that solves the problem. Also adds about
40HP with the headers.
>Marcus
>> Thomas,
>> >can help.
>> >Pete
>> >From: Thomas Warner
>> >>Areas of interest:
>> >> Performance Exhaust
>> >>to NY
>> >>Address:
>> >>3692 Hogan road
>> >>Phone: 315-829-3398
>> >>FAX:
>> >>Email: warner
>> Thx.....th
> coated. The reason that they run hot is that there is to much backpressure,(SNIP)
Well, I have the 3" exhaust from Jardine and the headers. The idea
is to keep as much heat in the exhaust pipe so that the heat and exhaust
are drawn out at the tail pipe. The ceramic coating does this and
also allows the engine compartment to remain cooler. The compartment
already has a heat problem. Before having mine coated they were very
hot (red glow at night). I had mine done by Swain Coating here in
Rochester and now I can almost touch them and not get burned. What I
had done was overkill as this stuff is used by the Air Force, NASA and
Nascar but he is close and it was easier than sending them to Jet-Hot.
Swain does not look as nice as Jet-Hot but is more effective and a few
more bucks.
If I ever do an engine I will have them do all the internals, such as
the bottom of the manifold, tops of pistons etc. The new ceramics can
control heat and friction in ways that were unknown in the past. Most
major racing - F1, WSC and endurance engines use the stuff and along
with
new syn oils the engine self destructing has gone way down. It truly is
overkill but all I want is the GMC to go like a Cobra, ride like a
Mercedes, and handle like a go kart. My wife says "OVERKILL" is my
middle name.
Marcus
As I understand it, thermodynamically speaking, the principal is that
the hotter exhaust gas can be kept, the faster it will flow, which leads
to more complete expulsion of the products of combustion in the engine
and consequently less back pressure. Thus, exhaust tubing that is
ceramic coated is more efficient in retaining the heat of combustion vs.
uncoated tubing, which radiates or loses heat.
Paul Bartz
> From: Marcus McGee [SMTP:crsalert]
> Sent: Thursday, April 09, 1998 7:07 PM
> Subject: Re: GMC: source for Thorley Headers
> headers coated. The reason that they run hot is that there is to much
> back pressure,(SNIP)
> Well, I have the 3" exhaust from Jardine and the headers. The idea is
> NASCAR but he is close and it was easier than sending them to Jet-Hot.
> more bucks.
> with new syn oils the engine self destructing has gone way down. It
> truly is overkill but all I want is the GMC to go like a Cobra, ride
> like a Mercedes, and handle like a go cart. My wife says "OVERKILL"
> is my middle name.
> Marcus
Exactly what I was trying to say, but Paul says it with such elegance.
Marcus
> Paul Bartz
Marcus, et al:
Another thing I should have discussed about ceramic coating is that it
provides longevity to the exhaust system.
When I decided to get my headers, etc., coated, I was looking for
longevity (don't want to have to replace exhaust system components a few
years down the road due to corrosion/rusting out) as well as a reduction
of heat in the engine compartment.
Some individuals claim uncoated headers increase engine compartment
temperatures, while others claim the opposite??
I understand that the coating put on the Doug Thorley headers during
production, is a cheap nickel coating. After use, it starts turning
colors and even rusts.
You can save a little money by purchasing the headers uncoated if having
them ceramic coated. Otherwise, the coater will need to sandblast it
off prior to coating, which costs extra.
Had my coating done at Hi Performance Coating (HPC) in Salt Lake City.
They were able to coat both the inside and outside of the tubing.
As a matter of fact, I got the best price on the headers from HPC with
the added advantage of saving cost shipping them to HPC.
Paul Bartz
> Sent: Friday, April 10, 1998 2:55 PM
> Marcus
> that
> leads
> engine
> vs.
> > Paul Bartz
Paul,
Do you have an address or phone number for HPC in Salt Lake City?
- -----Original Message-----
To: 'gmcmotorhome'
Date: Friday, April 10, 1998 2:40 PM
Subject: RE: GMC: source for Thorley Headers
>Marcus, et al:
> Paul Bartz
>> Marcus
>> that
>> leads
>> engine
>> vs.
>> > Paul Bartz
How much for the headers and how much for the coating?
>Paul,
>From: Bartz, Paul
>To: 'gmcmotorhome'
>>Marcus, et al:
>> Paul Bartz
>>> Marcus
>>> that
>>> leads
>>> engine
>>> vs.
>>> > Paul Bartz
Gilbert:
HPC, 550 W 3615 S, Salt Lake City UT 84115, 800-456-4721, Ext 18 (Cory
Ure, sales manager).
If you call, tell Cory I recommended HPC.
Paul Bartz
> From: Gilbert R. Bethel [SMTP:rbethel]
> Sent: Friday, April 10, 1998 6:22 PM
> To: gmcmotorhome
> Paul,
> From: Bartz, Paul
> Marcus, et al:
> few years down the road due to corrosion/rusting out) as well as a
> reduction of heat in the engine compartment.
> having them ceramic coated. Otherwise, the coater will need to
> sandblast it off prior to coating, which costs extra.
> Paul Bartz
> Marcus
> >> leads to more complete expulsion of the products of combustion in
> the engine and consequently less back pressure. Thus, exhaust tubing
> that is ceramic coated is more efficient in retaining the heat of
> combustion vs. uncoated tubing, which radiates or loses heat.
> Paul Bartz
Thomas:
Invoice was $490.00 (no breakdown of costs) plus shipping.
As I recall, coating was ~ $215.00.
Paul Bartz
> From: Thomas G. Warner [SMTP:warner]
> Sent: Friday, April 10, 1998 7:39 PM
> To: gmcmotorhome
> >Paul,
> >From: Bartz, Paul
> >To: 'gmcmotorhome'
> >>Marcus, et al:
> it
> few
> reduction
> having
> it
> City.
> with
> >> Paul Bartz
> elegance.
> >>> Marcus
> >>> that
> which
> >>> leads
> >>> engine
> is
> combustion
> >>> vs.
> >>> > Paul Bartz
