Hello,
So, I thought I had a bad exhaust manifold gasket and that the resulting
exhaust leak was making a lot of noise. Sure enough, the gasket had
disintegrated to almost nothing, so I replaced it this morning with a
Remflex, but when I started the engine, quickly realized that the bad
manifold gasket was not what had been causing the noise.
With the plastic fenders off, the engine hatch off, and the engine running,
I searched for the source of the noise. The noise is loudest from above. It
sounds like it's coming from inside the valve cover on the right side. As
far as I can tell, there is no exhaust leaking into the engine compartment,
but I swear it sounds just like blown out muffler.
I also noticed that the plastic electrical conduit that runs along the top
of the valve cover had been resting on it and was completely melted. I
didn't think the valve cover should be getting hot enough to do that.
If it wasn't so loud, I wouldn't think anything was wrong. It starts right
up, doesn't smoke and seems to have all it's power. Any idea what might be
happening here?
Thanks,
Steve T.
78 Eleganza
Santa Cruz, CA
happening here?
Thanks,
Steve T.
78 Eleganza
Santa Cruz, CA
