Solaire out but DOA
thomas g. warner
1,863
Finally got the solaire out after many bruised knuckles and lots of kicking
and cursing. It was missing many screws and someone had obviously taken it
out sometime in the distant past and put it in wrong. I really dont know
how they could have gotten it in. No matter what I did it would just not
slide out the sink side like the manual says. Decided that since it is not
in the best of shape now is the time to replace it along with the other pile
of parts I have to install before Februay 10th.
Need some experiences of those that have replaced the furnace of their
coach. What did you install suburban or hydroflame and why. How easy was
it to install. Did anyone buy the suburban bottom venting system? I want to
install and outside servicing door to it. Anyone do that? Where did you buy
the furnace. I noticed in my old notes that Cinnabar has a surburban made
specifically for the GMC that fits the curve of the outside wall perfectly?
Anyone used it?
Camping World has what appears to be a fantastic buy on the 30,000 BTU
suburban furnace for $436.30. Good or bad?
Thanks for any help.
>GMCers
>Roger has made a point with me. Give me population and auto stores
>in you area---then price.
>Take Care
>Arch
The Hydro-flame is an easy install. It can even sit on the angle to match the
wall. Total exterior servicing. Everything comes out the installation opening.
I like it. Darren
> Anyone used it?
> >GMCers
> >Take Care
> >Arch
Darren Paget
76 Experimental
Another Fab Day
http://www.TZEplus.com
Tom-
I installed a Hydro-Flame and it works great. Bought it from JWW, about $525..
It is not as tall as the OEM so it is easy to install. By design, all service is
from the outside new access panel. The outside curvature of the coach does not
interfere with the new outside panel if you carefully select the position of the
"box". If interested I'll send you pix privately (or to Gene and he can post
them?)
Gary
North Bend, Oregon Coast
> Anyone used it?
> >GMCers
> >Take Care
> >Arch
Thanks Arch. Is there room for the bottom plenum adapter that suburban sells?
>In a message dated 01/05/2000 9:50:43 PM Central Standard Time,
>> I want to
>buy
>> Anyone used it?
>Tom
>Glad you got the beast out. I installed a S 34,000. Cant tell you how good it
>is
>have not fired it up yet. Cant tell you about the Cinnabar unit but I can
>tell
>you that if you place a 1/2 spacer at the hall side of the furnace it will
>conform to the outside of the body. I dont know what Cinnabar does
>but somebody here followed my advice and said it worked. It did for me.
>Holler if you need more help--I changed the duct configuration---cant
>tell you if it works or not just did it. Will be glad to tell you what I did
>not how well it works.
>Take Care
>Arch
Gary I already chicened out and ordered the suburban from cinnabar for $525.
I am pressed for time and need to get it installed pronto. The suburban
comes with complete directions, and a kit made especially for the GMC. Hope
it works out OK.
Thanks for your help though.
>Tom-
service is
of the
>them?)
>Gary
>> Anyone used it?
>> >GMCers
>> >Take Care
>> >Arch
