solaire fire - now replacing the furnace
tipton eric
191
I did that, but we also use a vented catalytic heater mounted one the
entry wall below the vacuum cleaner storage. We then installed a new
two way hot water heater where the furnace come out. This is a great
setup for bonndocking, especially since we also changed the refrigerator
to a 3 way. If I had it to do over again, I would special order a 3 way
H/W heater with the radiator heat exchanger.
Eric Tipton
etipton
-----Original Message-----
Sent: Friday, June 18, 1999 1:20 PM
To: gmcmotorhome
Subject: Re: GMC: solaire fire
Just curious to know how many of y'all HAVE jerked the
Solaire and NOT
replaced it? I read of at least one GMCer who left the
furnace out and uses
electric ceramic cubes to heat the coach. Anyone else
done that and what
has been your experience?
Thanks
Dick 75 PB in Atlanta
>In a message dated 6/13/99 8:30:51 PM Central Daylight
Time,
>Chris
>I was lucky---I did not have a fire. On my 76 GB there
was a leak
>in the window over the sink. The mounting ears had
rusted off.
>The furnace was free to move about because somebody had
>taken the outside vent covers off and then just
rescrewed them
>to the outside skin of the coach. It had been run at
some time
>because the fiberglass was all burned and melted. I
would check
>any 20 something year old furnace. I put in a new one
so I would
>not have that worry. Thats what I did.
>Take Care
>Arch
>> i went for a ride sunday nite w/fam and about three
minutes going down the
>> street the kitchen cabinet started to smoke . the
solaire furnace was
>smoking
>> on the left side where the wires go in and a fire
was starting inside.
>> luckily i had water in the tank and put it out. has
anyone had this type
>of
>> problem.this could of been a tragedy.
>> chris 75 gb
