Sol Aire Furnace
eieioh
41
Emery Stora said . . . .
If you still have problems even with the new thermostat let me know and I'll
see what else to recommend. By the way, I have the original manual for the
Solaire if you need a copy.
Emery,
I too have been having trouble with my Sol-Aire furnace. The blower fan runs
but there is no ignition. My LP gas tank if full and the pressure regulator
is fairly new. I pulled the furnace for a visual inspection and found it to
be clean and sound. With 12 Volt power to the motor, the centrifugal switch
operates normally and the solenoid gas valve tested okay. I don't know how
to check the ignitor (aka spark electrode) or if a replacement is available.
Any advice would be greatly appreciated.
Bill Macdonald
77 Kingsley
Beaverton, OR
(503) 526-8649
eieioh
