just had a talk with al and he thinks if the gas does not ignite after a
while, the braker is popped....
Have to look in manual. does it get hot while running?
Also the batt has to be up with the voltage high so the fan can get up to
speed and turn on the gas.
gene
>Hey All;
> Was wondering if anyone had seen these symptoms before in relation to a
>Sol-Aire furnace in a 76 Palm Beach. It puts out heat but for only a couple
>of minutes and then shuts off. It can get started again (push the reset
>button) but then it doesn't heat and only stays on for a couple of seconds.
>What would cause the reset button to pop? It hasn't been run in 10 years, so
>could this be the fan dragging?
>GaryB
>76 PB in Ca.
>______________________________________________________
>Get Your Private, Free Email at http://www.hotmail.com
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
gene
>Hey All;
>GaryB
>76 PB in Ca.
mr.erf
