So what did you do to your GMC today?
Installed my rebuilt CV, bled the front brakes, installed the front Ions, and gave R2 a much needed wash. Took a break and decided to start it up to let it run for a while. It took longer than normal to fire after a sitting period, but did fire up eventually. Did my normal checks on the ground for anything leaking. Smelled fuel and tracked to the fuel line past the tank selector that had split and was seeping. Will work on that and final drive gear oil change on Sunday. Its starting to get there mechanically!
I finished my door handle, and all the repair work on the door panel. The interior decorator decided I needed to utilize our accent color.
I also mounted a blind-spot mirror. I think I like it, but I haven't driven with it yet. I do believe I'll order a second one. I'll cut the stud off shorter and cap it with a stainless acorn nut as the final touch.
Fix spare tire mount and mounted the spare Ion. Replaced fuel line between tank selector and hard line point beneath drivers area. Found the vent line that runs back to the charcoal canniser was chewed on, so will splice in a section of new hose. Also noticed 90 degree'ish hose for the filler may be a repurposed radiator hose so will look to source a proper replacement.
Cleaned the front Carrier Air V. It had developed a musty smell.
Considering how filthy it turned out to be I was surprised it was working as well as it did. Ended up disassembling a good bit of it for access and cleaning covers and fans, along with a few applications of foaming coil cleaner and rinsing. Took hours to do it right.
I poured some Seafoam into the gas tanks and drove it down to the emissions testing facility. It passed with flying colors. I hadn't driven it since the last Saguaro Jetset rally in April, We're preparing it for a mid Summer trip to Woods Canyon Lake up on the Mogollon rim, above Payson, AZ. The elevation is about 8000' up there, so it should be nice and cool. Getting there is a different story, driving through the 1300' Phoenix valley and 100+ degree temps.
I finally had the parts and the time to start working on installing block off plates on my intake manifold exhaust cross over. With only approximately 3,000 miles on a rebuilt motor, I was discouraged to see the paint on the intake manifold blistered and baked where the exhaust crossover goes. Obviously, the mechanic, who was an old timer, didn't know of the need for block off plates. I also discovered no (or so small of an amount it wasn't discernible) gasket sealant on the manifold gaskets.
I was able to remove and clean-up the intake manifold today. I was also able to get it painted. Tomorrow I hope to get it put back together.
I'm also hoping that this will solve my stalling issue.
Reactions: RoadTrippin
You got the intake off with the distributor in place? You are a better man than me! :)
You do have a crack in your intake. If I can see it from here, I think you'll want to find out how extensive it is. It can cause decent vacuum leaks once fully warmed up, and they're really tough to troubleshoot since all the typical vacuum leak detection tricks don't work.
My advice, with a known crack, would be to fill the intake crossover port with aluminum rather than using block off plates. JWID.
Straightened the condenser fins from hail damage on the front roof A/c unit.
Rear A/C does not cool but this is what the front fins looked like from hail damage
When I was 70 % done the plastic comb the fingers twisted and bent making it unusable.
I used the pointed end of a 5 to 1 paint scraper to finish straightening the fins. Worked like a charm. Took less than an hour.
Are those metal fingers? 14 per inch?
The pitch isn't really designed to match the fins. They are very compliant. You dig them into the "good spot" and they clump together to form a spacing they sorta maintain as you rake it down. They're essentially universal. You can also slide the collar up and down to alter stiffness for maximum efficacy.
Reactions: Tom Katzenberger
