Sounds like me, it is time for you to try the single rear muffler..... One
of my mufflers -- the insides came loose. so I am going to throw them both
away and go to the single rear.
did you reduce your tbi pressure now that you found the problem ??
gene
>In a message dated 2/22/00 5:57:51 PM Mountain Standard Time,
> Where did you find hills in South LA? Approaches to the bridges?{:>) The
> Levees?
> Roger >>
>Now you know that I had a real problem. We wouldn't even call them hills in
>New Mexico!
>Emery Stora
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION mr.erf http://www.california.com/~eagle/
Emery... did you revert to the original settings you had on the knock
sensor. I was curios when you called if the changes made any difference in
knocking.
al
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
