Six Wheel Alignment
I could use some assistance on this....
After replacing my front knuckles,
Not hearing anything on this (except for the brake light problem) I'd
like to ask again. One possibility; could the torsion bars be swapped?
Seems like if they are interchangeable, this would halfway solve the
problem.
Steve Ferguson
San Diego
The torsion bars are not intchangeable and may be the cause of some peoples
front end problems if someone has installed the incorrect ones. They are
clearly marked.Right 702524 and left 702525
>problem.
>Steve Ferguson
>San Diego
> peoples front end problems if someone has installed the incorrect ones.
> They are clearly marked.Right 702524 and left 702525
This made me think of an observation I made back when I was restoring a lot
of Corvettes. It isn't 100% infallable, but is pretty close: GM used even
numbers for right-side components and odd numbers for left where there are a
left and right pair, such as headlamp bezels, axles, exhaust manifolds,
whatever. For instance, if you've got a pair of parking lamp lenses in your
hands and forgot which one goes on which side, you can be _almost_ certain
by the odd-even trick. Helps sometimes when you're putting things back
together. I'm not sure I've ever seen an exception, but I kinda think I
have.
The only other part-number trick I remember is that on a Rochester (GM)
carburetor from this era, the fourth-from-last digit in the part number is
the year model ie 7040204 is from a '70 model; 7041204 is basically the same
carburetor but '71 model. Starting in '76 if I remember correctly they put a
leading "1" as in 17046204, but the year model is in the same place. 7040204
is a valid number for a quadrajet for a 70 396 or 454 in a Chevelle, FWIW.
Hope this helps someone someday; hate to take all this hard-won triviata to
the grave without someone benefitting!
Travis
It is my understanding that the torsion bars should NOT be swapped
after use. Once they take a "set" in one direction, reversing them
risks breaking them.
Rick,
Thanks! That's what I've been looking for! I haven't had them out yet,
plan on doing that later this week, along with replacing the control arm
bushings. On quick inspection, it appears that it might be possible to
swap them side for side if the right front goes to the left rear etc.
This will keep the twist in the right direction.
I have some pretty good assistance where I store the GMC in E. El
Cajon & they do a lot of off-road race stuff. They routinely replace
Blazer, Suburban, Van etc..bushings without removing the control arms
from the vehicle. Yeah, I know what you're thinking, me too, but they're
real deal people with a lot more experience in this than I have so if
they say it can be done, it most likely can be. I'll keep the net
posted.
Steve Ferguson
San Diego, CA
