single muffler Cooling the engine compartment
david l greenberg
8,798
1
On Wed, 01 Mar 2000 21:57:02 -0800 Claude Brousson
writes:
> One further thought on this-I certainly agree it is desirable to get
> rid
> of heat if one can. So far I have approached the problem a little
> differently than moving the muffler to the back.
> I built some sheet tin deflecters behind the headers to drive the
> heat
> down toward the road. I have installed my old ceiling fan under the
> passengers side to drive heat out the side vent which I and many
> others
> have installed. This is on a switch which I turn on if I am stopped
> in
> hot and slow heavy traffic.This pulls the heat away from the
> carburator
> area. I have the metal gas line to the carb running through an
> insulated
> fireproof hose to help keep the gas cooler. I have a metal spoiler
> behind the mufflers deflecting the wind and heat down toward the
> road
> and away from the gas tanks. And I have the bottom of the gas tanks
> painted white to reflect heat from the asphalt back down rather
> than
> into the tanks.
> I do not use an electric fuel pump, and so far have never had
> vapour
> lock. However, to be fair,I don't travel in the south, and in the
> desert
> when it is super hot. If I did, maybe I would have a heat problem as
> many others have.
> I would like the headers to not radiate so much heat, but still
> exploring how best to do that without costing an arm and a leg so to
> speak, with something which may not be permanent.
> Each to their own way, as always,
> Claude
I was thinking of adding a 5 ton home air con unit to my engine
compartment to keep all my mods and improvements cool. Any ideas on space
req'd? :)
David Lee Greenberg
The GMC Motorhome Registry
Dedicated To The Classic GMC Motorhome
www.gmcss.com/registry.htm
