Fred:
Just wondering what difference you see if it takes longer to cool the engine
compartment area after engine shut down without vs. with same side vents?
I've found that if you open the front access doors after shut down, you'll
feel a significant amount of rising hot air escaping for a short while. But
if it takes longer without facilitating the venting process, so what?
I too, share your reluctance vs. the unsubstantiated benefits, particularly
after I've installed ceramic coated headers.
Paul Bartz
Sent: Monday, November 23, 1998 12:29 PM
Subject: GMC: Side Vents - GMCMh
Has anyone done an analysis of the benefits of the side vents? By this I
mean before installing the vents, document the engine compartment
temperatures after engine shutdown over time; then for the same conditions
document the temperatures after installing. Without a forced air system (as
in a boat), I am reluctant to cut holes in the body for the vents unless the
benefits have been documented and demonstrated to be worthwhile.
Paul Bartz
