Scott,
We added a gray water tank to ours. It was actually one of the first
things we did to our GMC. We have a separate valve that we can open to let
it out on the ground or another valve that lets us let it out through the
regular black water outlet. We usually just leave the ground valve open
(we made it so that we can open this one from inside) if we are on grass
because it soaks right into the ground. If we are on pavement, we usually
close it so we don't have a big puddle around our motorhome. It really
cuts down on the need to empty the black water tank.
Zak
>I now think someone was trying to eliminate most of the grey water from
>filling up the holding tank. The cap on the end of my discharge pipe has a
>small nose connection on it so I guess they just attached a hose to it. I do
>not have a grey water holding tank but now that I spent some time looking at
>my plumbing system maybe there is some way to do it. Larry, I will crawl
>under the coach and try to figure this change out and how they did it. ( My
>guess is they removed the bathroom module but I will check it out better)
>Scott Adohen
Zak
>Scott Adohen
