Shogun tranny cooler
vic marks
220
Ron wrote: Can't seem to picture this cooler, Guess it just goes around
bellhousing?
Air entering/exiting thur inspection cover. guess that gets air to the heat
source.
Ron: It is bolted onto the flywheel/ring gear, which means that it is no
small job to install. You have to pull the transmission to install it. If
you're up for it, I'll send it out to you if you give me an address.
Ron also wrote: I ordered Ragusa's pan. And made some brackets to reinstall
maxikool cooler in place of the three tube cooler. And going to get another
sender and switch to monitor pan temps.
Ron: Can I ask a favour (note the distinctive Canadian spelling): How about
doing these installs one at a time and testing how each one affects the
temperature over a standardized route. I'd really like to see if the Ragusa
pan had any effect before you installed the maxikool, and then, what effect
the better cooler had on it. Are you running a synthetic oil (which I
understand to run somewhat cooler and to be better able to handle the
higher temperatures.
Good luck.
Vic
Date: Fri, 10 Dec 1999 17:37:23 -0800
Subject: GMC: frame rails
Scott wrote: My rails are 16' 8" long, no welds(26' coach). I had them
made at a total
cost of about $300.00. I had to drill all the holes myself. I used the
old
rails as a template. At the time I did my rails, Cinnabar wanted $1,500
for
the pair plus the cost of shipping to me.
Scott: do you know how much your rails weigh? I'd very much like to find
the weights of the various frame components: rails, bogies, bogie support
frame, crossmembers etc. Can anyone help me with this?
Vic
Vancouver BC
> you're up for it
Thanks for your generous offer, But don't want to get that deep at this
point. Hopefully I'll have many more miles before any work of that type.
Vic, Will test ea. on my same test route. And put readings on net. Guess
the pan will be first, got it today. When I get to it that is. Was going to
make another Raider run, But last week lighten my wallet quite a bit, Then I
tried to make it up across the river, Which was another no-no. So even tho
the $'s are lighter, I guess our Lady will be in a rest/can work on mode for
a while now.
Thanks again for you offer!!!!! Season's Greetings to you and
yours!!!!!!!!!!!!!
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
To:
Cc:
Sent: Friday, December 10, 1999 5:42 PM
Subject: GMC: Shogun tranny cooler
> bellhousing?
heat
> source.
> small job to install. .
reinstall
another
> RonI'd really like to see if the Ragusa
effect
> Good luck.
> Vic
Vic,
No, still on Dino. Was going to switch, But thought I'd better see if I can
lower temps first. Since I'm looking at fluid change at closer intervals. If
all my readings are right.
Thanks again
Ron
To:
Sent: Saturday, December 11, 1999 4:25 AM
Subject: Re: GMC: Shogun tranny cooler
> > you're up for it
to
I
for
> a while now.
> yours!!!!!!!!!!!!!
> Ron&Gina
> 73 Pumpkin-Rose
> Ft. Mohave, AZ.
> From: "Vic Marks"
> To:
> Cc:
> > bellhousing?
> heat
> > source.
> reinstall
> another
> effect
> > the better cooler had on it (which I
> > Good luck.
> > Vic
