The larger outer diameter rod could
give enough additional side load bearing surface at the bushings to
prevent
the shock from getting sloppy as quickly due to unaligned mounts.
Zak,
When I reinstalled the front shocks on my GMC last weekend I couldn't
help but notice how misaligned the mounts were. With the top mounting
bolt in place & tightened, the bottom of the shock mount was at least
1/2 inch away from being seated against the shoulder of the mounting
stud. With the bottom nut in place this probably puts a lot of side
stress on the piston or the mounting eyelets. Both sides are like this
so if I spacers won't get the shock into alignment, I can see where I'll
have to cut & re-position the upper mounting bracket. From what I've
read here, I would bet that my GMC isn't the only one like this.
Steve f.
prevent
Zak,
Steve f.
