Shipping New coach
johnny
8,287
9
3
If the rear wheels and bearings are good, run the suspension all the way up and a wheel lift single axle wrecker will tow it easily. Probaly with a
heavy enough tow dolly you cold haul it behind a 3500 pickuop. Otherwise, flat trailer is the answer.
Is it close enough to working tobring it home o0n a boat tank un der its own power? The investment in working brakes and tires you have to ake anyway
and it might be less than a towing charge.
Mine came home on a Haynes 500. With a heavy duty pickup, a Big Tex flatbed trailer would carry it.
Haynes builds - or built - wreckers. The 500 was a sigle axle on a Ford F450 chassis with a wheel lift and a boom. Alton Edge locally hauled mine
with one. I figure it would go for less than the big stuff many serv9ces want to use.
IMHO, this is the best way to "tow" our coaches. I got lucky. This towing service (Irvington Garage) is about 2mi from my house, and most of the guys
that work at this business were students in the school I taught at. Used them twice. Both times about 250 miles from home. Hope things work out for
you as good as it did for me.
http://www.gmcmhphotos.com/photos/our-coach/p56437-towing-our-coach.html
Larry
78 Royale w/500 Caddy
Menomonie, WI.
If brakes and bearings are in good shape or can be made functional, I've toyed with the idea of setting up a GMC for flat towing.... Does anyone know
of this having been done in the past or any thoughts on flat towing a GMC? I haven't seriously considered this, but have had some idle musings about
what it would take to do this for buying a project coach or recovering a disabled one...
Anyway, my thoughts got about this far:
1. Pull the halfshafts and install just the outer joint in the hub without a shaft attached, then cover or install inner joints to keep dirt and dust
out of the fd...
2. Use a Brake Buddy or equivalent (Using the one from my toad came to mind) to actuate the brakes in the GMC
3. Pull the front bumper and fabricate or modify a towbar to fit the bumper mount... Several options for this.... It could be done by: 1. building
one from scratch if you have the tools/skills, or 2. at least around here in TX, there are a lot of mom and pop trailer manufacturers and/or other
metal fabricators that could probably make what you need, or 3. If you look on ebay, etc. there are generally heavy duty military surplus tow bars and
connectors available that could be suitable if modified.... Something like this:
https://www.ebay.com/itm/Military-Towbar-Medium-Telescoping-Arms-With-3-4-Inch-Feet/264308643325?hash=item3d8a05d5fd:g:rkgAAOSwivlczKE-
Now you'd of course need a heavy duty pickup or some other truck to pull this... Also, it might make sense to make a tow plate that runs between the
front frame rails on the bumper mounts to reinforce the front end since the bumper is removed....
Again, I have not attempted this, nor am I aware of anyone doing this, though it does not seem out of the realm of possibility.... Of course, if you
do not have or have access to a heavy duty truck, Brake Buddy, etc. the cost on this would go way up... But if you already have or have access to
those things, the only real cost would be the tow bar.... But I would bet that won't go more than 2-$500 bucks if you're willing to scrounge around
and/or make what you need....
And of course, having not driven anything like this, it may not "pull" well at all, which makes this an experiment, for sure... I do not think I
would attempt running a rig like this through the Rockies or anything like that..... Texas to Wisconsin? It's a hike for sure, but pretty flat
depending on the route you take....
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
This has been done before.
Bob Drewes once towed a GMC at least a couple hundred miles by removing the inner shafts. I don’t know what he used for a towbar. He towed with a large pickup.
I believe the Curtis’s towed the frame of the burnt double bogie, 10 wheeled Midnight Express from the Bay Area to Northern California. Fay Curtis could likely give more details.
Frederick CO
> out of the fd...
> Howell Injection,
> Fort Worth, TX
If it can do that flat tow, it’s only a working power train away from driving. So—Get that done locally and drive it.
Kinda the way I am thinking about it. A heavy duty "Reposession Wrecker"
that just raises the front end off the ground, really, really is all that
is needed. They do a great job, and are far less money than a big tilt back
or tractor-trailer combo.
Get the darned thing fixed locally and limp home is another option.
Although, one could just torch off the half shafts, mickey mouse some kind
of tow bar, and drag it home, too.
On Tue, Jul 21, 2020, 8:33 AM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
When I had mine towed from Texas to Colorado they had to cross state lines at Oklahoma and Colorado and I was told they could not legally tow it with the smaller wrecker so they did overkill using a giant rig. Besides charging me $10 per mile, they broke my driveway and did about $1200 of damage to the concrete and to the GMC backing it into the drive.
I would have been better off towing it to the State Line, using my Tracker to push it across and using another smaller tow truck to tow it home.
> Salem, Oregon
>> John Lebetski
>> Woodstock, IL
>> 77 Eleganza II
I flat land towed mine home last fall for 63 miles with my Colorado PU. The cruise control on the PU was set at 55 mph the whole way.
Some additional things you will need:
1. A magnetic light bar for rear of coach with tail and brake lights attached to ad powered by the tow vehicle.
2. An electric vacuum pump attached to the GMC brake booster if you intend to use a "brake buddy".
3. A 12 volt circuit from the towing vehicle to the GMC engine battery to keep the battery charged for parking and clearance lights plus the vacuum
pump. I suggest using a 7 pin round trailer plug on the towing vehicle for all of the electric stuff.
> know of this having been done in the past or any thoughts on flat towing a GMC? I haven't seriously considered this, but have had some idle musings
> about what it would take to do this for buying a project coach or recovering a disabled one...
> dust out of the fd...
> 2. Use a Brake Buddy or equivalent (Using the one from my toad came to mind) to actTuate the brakes in the GMC
> building one from scratch if you have the tools/skills, or 2. at least around here in TX, there are a lot of mom and pop trailer manufacturers
> and/or other metal fabricators that could probably make what you need, or 3. If you look on ebay, etc. there are generally heavy duty military
> surplus tow bars and connectors available that could be suitable if modified.... Something like this:
> the front frame rails on the bumper mounts to reinforce the front end since the bumper is removed....
> you do not have or have access to a heavy duty truck, Brake Buddy, etc. the cost on this would go way up... But if you already have or have access
> to those things, the only real cost would be the tow bar.... But I would bet that won't go more than 2-$500 bucks if you're willing to scrounge
> around and/or make what you need....
Seems to me it would be cheaper, safer, and less trouble to just keep a
service like Allstate's RV Roadhelp, which I've had for 22+ years. Sure,
I've paid them a lot of subscription fees during that time, but I've also
been towed several times without any hassles nor worries. My overall
coast has been much less than if I'd worried about and paid for the
individual tows.
Now for short distances, like 5 miles to the service station, I've had HER
get in the toad to work its throttle, dependent upon the condition of the
GMC's brake lights. NO problem to me -- SHE HATES IT!
If I were determined to try flat-towing the GMC, in the proposed step 1.,
I'd remove the front axles at the 6-bolt inner flanges rather than trying
any other way to keep them out of the way -- especially since I'd have to
remove them anyway to get the stub (half) axles to go into the hubs. DON'T
try towing without re-installing those stubs!
JMHO,
On Tue, Jul 21, 2020 at 11:01 AM Mark Sawyer via Gmclist <
> about
> disabled one...
> out of the fd...
> building
> and
> like this:
> you
> Howell Injection,
> Fort Worth, TX
