Serpentine?
Along with wrong size belts I believe there are a number of reasons why the
old GMC has belt hucking issues. In my opinion they are (in no specific
order by causation)
1.Cheap belts in the “correct” size and profile
2. Improper pulley size such when an alternator or power steering pump has
been replaced and it is supplied with the “wrong” drive pulley.
3. Pulley misalignment. The various accessories driven from the engine are
very specifically mounted to the engine and it’s pretty complicated and
quite easy to re assemble the various accessories and have them “work” but
not be correct. Multiple overlapping brackets and specific assembly order
lends itself to improper re assembly especially when coupled with poor
repair access and visibility. It is very difficult to see if all of the
pulleys are properly aligned with the radiator/fan shroud etc installed.
Often when the power steering pump is replaced the pulley needs to be
pulled from the old pump shaft and press positioned onto the pump arbor.
The PS pulley therefore needs to be properly aligned with the crank pulley.
Simply measuring the distance from the end of the original shaft may not
properly locate the pulley due to body housing differences, different shaft
length etc.
4. Missing “non essential” support bracketry such as the top alternator
support stay.
When I assembled the motor and it’s accessories I did it on the cradle with
the entire assembly out of the coach. This allowed me to check pulley
alignment where I could actually see and check with a straight edge.
Multiple bracket re location efforts were completed to end up with all of
the pulleys in the correct plane.
All of these issues when coupled with the disappearance of correct quality
belts is likely the driving force behind the desire for a simplified
serpentine belt system.
Sully
Bellevue wa.
On Thu, Jul 12, 2018 at 8:16 AM Emery Stora via Gmclist <
> Jon -
> Probably due to the brand of the belt and the tension.
> I have had a 100 amp alternator for over 20 years and I don’t have an
> squeal or belt life problem and I have the single groove pulley on the
> alternator.
> Someone with that problem should probably try an industrial belt. They
> are available in the sizes we need and are a much stronger and better
> gripping belt. I have not had to use them but I know some that have and
> they are very happy with them.
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > I am surprised that someone would want to go serpentine. Great that we
> have iotions.
> > I also do not understand the bigger alternator in todays world. I just
> think in today's LED world,
> > It is easier to set your coach up to be more energy effecient then to
> find a way to produce more amps. Just seems more amps means more wear and
> less
> > life on components.
> > I have a rebuilt stock alternator, and have never felt a need for any
> more amps.
> > See many who have the 100 amp with no problems on a single pully, yet
> others cant keep a belt. Strange.
> > Jon Roche
> > 75 palm beach
> > St. Cloud, MN
> > http://lqqkatjon.blogspot.com/
Here is a link to photos of my serpentine set up. My po was Bobby Moore.
I haven't had a problem with it and done about 6000 miles. I had to repair the alternator at a camp ground one night and the serpentine belt made this
an easy task https://photos.app.goo.gl/ESVzG7PBQ53Kqsvw9
Trevor
Brisbane Australia
Siesta Koala 76 Edgemont (old Bobby Moores)
71 Cadillac Eldo Convert
58 Cadillac Eldorado Brougham Project
Trevor,
When I get back to Australia I'll fly up and check out the system as installed, probably some time in October.
I've got the last two kits Bobby and JR made.
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Trevor Pordage
Sent: Thursday, July 12, 2018 6:02 PM
Subject: Re: [GMCnet] Serpentine?
serpentine belt made this an easy task
Trevor
> this an easy task https://photos.app.goo.gl/ESVzG7PBQ53Kqsvw9
that looks like he used an existing tensioner bracket from some other GM (probably a truck) and adapted it. and also one other piece of thick steel
tubing for the tensioner and bolted it to the mechanical fuel pump mounting holes.
beautifully simplistic! Ive seen some crazy street rodders that made everything out of billet from scratch that didnt look as nice.
thanks for sharing
Rob, Trevor, et al,
The main modification I made to my copy of the JR/Bobby serpentine was to
remove the fuel pump-mounted tensioner. It was, IMHO, redundant and
created too much slack in the belt. I never missed it.
> made
> mounting holes.
> thanks for sharing
I think Blaine just installed a serpentine system on his 76 Palm Beach. I did not pay much attention on what system he used as I was not really
interested.
Ken,
Blaine is using the set-up I came up with. But, he has it mocked up on a
spare motor and is first installing an EFI project on the coach.
So it's not on the coach yet.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Friday, July 13, 2018 2:25 PM
To:
> interested.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
