Serpentine Belt setup
The coach has an electromotive Tec2 fuel injection and ignition system. They make an ignition control only box as well, uses a 60-2 crank trigger
wheel. My system runs great but is no longer supported. I am considering my replacement options while it still runs great. This is there ignition
system
http://www.ebay.com/itm/Electromotive-XDI-8-Cylinder-Complete-Distributorless-Ignition-package-/311863507134?hash=item489c8378be:g:ODMAAOSw~y9ZC6i6&vxp=mtr
> Please tell me more about the crank triggered ignition. I'm working on
> designing a crank triggered ignition for both the Cadillac and Olds.
> It's slow going, because my body can't get the things done that my mind can
> promote. LOL
> Gary Kosier
> 77PB w/500Cad
> Newark, Ohio
> From: "Jdlisenby"
> Sent: Tuesday, August 29, 2017 10:07 PM
> To:
> Subject: Re: [GMCnet] Serpentine Belt setup
> > The coach has crank triggered ignition and the timing is set on the
> > laptop. I would like a more OEM pulley style setup as appearance is not
> > important
> > and it would be a heck of a lot cheaper, that's why I asked if anyone had
> > tried it. I figured with all the issues V-belts cause, someone else might
> > have already solved the issue (don't reinvent the wheel etc etc). I
> > figured this would make a good winter project.
> >> Before you get real excited about that March serpentine, think about
> >> trying
> >> to hit the crank pulley with a timing light.
> >> It's difficult enough with a stocker, but impossible with that
> >> concoction.
> >> Gary Kosier
> >> 77PB w/500Cad
> >> Newark, Ohio
> >> From: "Jdlisenby"
> >> Sent: Tuesday, August 29, 2017 8:41 PM
> >> To:
> >>> As luck would have it I will be picking up CoRVy on Friday and I will
> >>> ask
> >>> Jim about it. I would love a no-frills March setup.
> >> GMCnet mailing list
> >> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
> > JD Lisenby- USAF Ret
> > 1978 Royale-455
> > Electromotive Tec2 FI & ignition
> > Navarre, FL
1978 Royale-455
Navarre, FL
Jim,
I'm not on the cruise with you guys, however, I'd say quite a few of the guys on the GMCnet are "in the same boat!" ;-)
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Hupy
Sent: Thursday, August 31, 2017 3:01 AM
Gary, if you think it is bad today, just wait a few years. (Grin) Jim Hupy presently in Vienna, Austria with 50 or so of our GMC
Friends. On a river cruise.
> can promote. LOL
> Gary Kosier
> 77PB w/500Cad
> Newark, Ohio
Interesting! Those coils are the GM Waste Coils as used on a bunch of
vehicles. My concoction is based on the ignition control module
with those coils as used on the 93-99 Cadillac Northstar. Since that motor
becomes an unserviceable lump at about 100k miles, the
modules become readily available in the men's mall. It does require a GM
ECM to provide an advance protocol. Obviously, the EBL
conversion normally used in the GMC conversion to EFI. I should add that
one of my sources has it working with MegaSquirt EFI.
I am going to try to have a show-and-tell display at Elkhart if you're going
to be there.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Wednesday, August 30, 2017 5:17 PM
To:
> system
>> can
>> promote. LOL
>> Gary Kosier
>> 77PB w/500Cad
>> Newark, Ohio
>> From: "Jdlisenby"
>> To:
>> > not
>> > important
>> > had
>> > might
>> >> trying
>> >> concoction.
>> >> Gary Kosier
>> >> 77PB w/500Cad
>> >> Newark, Ohio
>> >> From: "Jdlisenby"
>> >> To:
>> >>> will
>> >>> ask
>> >> GMCnet mailing list
>> > 1978 Royale-455
>> > Navarre, FL
>> > GMCnet mailing list
> 1978 Royale-455
> Navarre, FL
Well, sorry guys. I typed up a long explanation of the serp setup.
But the list moderator rejected it as too long. I'm too tired to sort it
out
and try to fix it.
Gary Kosier
77PB w/500Cad
Newark, Ohio
That sucks! After seeing your Cad solution I am really interested in what you came up with. There are a lot of things I can do but fabrication isn't
my strong suit.
1978 Royale-455
Navarre, FL
I wish I could go but we can't make it this year. I have been looking at the MegaSquirt, Halltech and even the Fitech port injection. I hate the idea
of going backwards to a throttle body setup. The coach runs great as is but if the ECU takes a dump I will be dead in the water without a replacement.
I like the fact the coils are readily available and the tuning is flexible but frankly electromotive lost some key people and their tech support is
lacking. If I get a newer version of their ECU I can just load up my Bin file and go. I am really looking at all possible options to keep port
injection and run a modern ECU.
> to be there.
> Gary Kosier
> 77PB w/500Cad
> Newark, Ohio
> From: "Jdlisenby"
> To:
> > system
> > http://www.ebay.com/itm/Electromotive-XDI-8-Cylinder-Complete-Distributorless-Ignition-package-/311863507134?hash=item489c8378be:g:ODMAAOSw~y9ZC6i6&am
> > p;am p;vxp=mtr
> >> can
> >> promote. LOL
> >> Gary Kosier
> >> 77PB w/500Cad
> >> Newark, Ohio
> >> From: "Jdlisenby"
> >> To:
> >>> not
> >>> important
> >>> had
> >>> might
> >>>> trying
> >>>> concoction.
> >>>> Gary Kosier
> >>>> 77PB w/500Cad
> >>>> Newark, Ohio
> >>>> From: "Jdlisenby"
> >>>> To:
> >>>> > will
> >>>> > ask
> >>>> GMCnet mailing list
> >>> 1978 Royale-455
> >>> Navarre, FL
> >>> GMCnet mailing list
> >> GMCnet mailing list
> > 1978 Royale-455
> > Navarre, FL
1978 Royale-455
Navarre, FL
If you already have a port injection manifold, I would recommend sticking to
all GM parts, where possible. The advantages are good quality,
ready supply of parts both new and used, cheap prices, and terrific support
from the GMCMH-EFI group. The EBL P4 conversion from
Dynamic EFI gives easy adjustability to your individual combination. And,
of course, it will support my concoction of distributorless ignition.
GM is going to be around for a long time and there is a wealth of
documentation on all their stuff.
More to come!
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Wednesday, August 30, 2017 10:11 PM
To:
> idea
> replacement.
>> motor
>> going
>> to be there.
>> Gary Kosier
>> 77PB w/500Cad
>> Newark, Ohio
>> From: "Jdlisenby"
>> To:
>> > system.
>> > trigger
>> > considering
>> > ignition
>> > system
>> > p;am p;vxp=mtr
>> >> on
>> >> mind
>> >> can
>> >> promote. LOL
>> >> Gary Kosier
>> >> 77PB w/500Cad
>> >> Newark, Ohio
>> >> From: "Jdlisenby"
>> >> To:
>> >>> is
>> >>> not
>> >>> important
>> >>> anyone
>> >>> had
>> >>> might
>> >>>> about
>> >>>> trying
>> >>>> concoction.
>> >>>> Gary Kosier
>> >>>> 77PB w/500Cad
>> >>>> Newark, Ohio
>> >>>> From: "Jdlisenby"
>> >>>> To:
>> >>>> > will
>> >>>> > ask
>> >>>> GMCnet mailing list
>> >>> 1978 Royale-455
>> >>> Navarre, FL
>> >>> GMCnet mailing list
>> >> GMCnet mailing list
>> > 1978 Royale-455
>> > Navarre, FL
>> > GMCnet mailing list
> 1978 Royale-455
> Navarre, FL
my previous owner Bobby Moore installed a serpentine belt setup on my coach .i dont know much about it . i took some photos yesterday but it is
difficult to get good shots i posted them in the gmc photo page if searching for them use serpintine i spelt it wrong
http://www.gmcmhphotos.com/photos/mechanical/p63657-serpintine-belt.html
Trevor
Brisbane Australia
Siesta Koala 76 Edgemont (old Bobby Moores)
71 Cadillac Eldo Convert
58 Cadillac Eldorado Brougham Project
Trevor,
Bobby was a very creative person and had many different projects on his coach each year. First met him in 1999 and the Myrtle Beach GMCMI spring convention.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 30’ Stretch
Michigan
> Trevor
> Brisbane Australia
It's my understanding that Bobby and JR Slaten developed that serpentine
system together. Bobby gave me the 3rd set they made. There seem to be
some differences between Trevor's set and mine, but then I made some
changes myself so they may have been identical earlier. That engine and
belts are on the engine in my son's coach, so one day maybe I'll get a
chance to make photos of it to post. I must say that it's performed
flawlessly for maybe 70,000 miles, even running the OEM-style Water Pump
backward.
I did have some WP problems not long before I installed the Cad 500, but
they were all occurred while I was testing protypes of Leigh Harrison's
reverse flow design. The final version of that is still hanging on my
storeroom wall, unused. That was before the 350 diesel reverse flow pump
was discovered. When the last prototype failed on me, I installed an Auto
Zone severe duty pump, without even improving the flow pattern as I'd done
previously. My son's probably put 15-20,000 SE USA miles on that with no
overheating problems.
I still think a simpler system, using two serpentine belts, can be made for
very little cost -- I haven't yet seen Gary K's version.
Ken H
On Thu, Aug 31, 2017 at 3:29 PM, Trevor Pordage
Trevor,
Thanks, Mate!
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Trevor Pordage
Sent: Friday, September 1, 2017 5:29 AM
yesterday but it is difficult to get good shots i posted them in the gmc photo page if searching for them use serpintine i spelt it
wrong
Trevor
i am discovering how creative bobby moore was there are lots of little extras. when i first got the coach i noticed how all the slots in the screws
are in vertical alignment as well as the crosses in the phillip head screws are all in the same orientation . this indicates to me how much thought he
put into everything
Trevor
Brisbane Australia
Trevor,
How 'bout that electric parking brake? Previously an electric seat
adjuster, IIRC. :-)
Bobby was the very first GMCer we met in '98. We attended our first GMC
rally at Lake Lanier Islands, GA in our 40' diesel pusher before getting
the GMC road-ready. We were parked well away from the GMC's and
encountered the Moore's enroute to the "rest of the crowd". It took a
couple of hours to get to the "rest of the crowd". Our friendship grew
continuously from then until he passed away; I learned a LOT from him.
On Mon, Sep 4, 2017 at 4:26 AM, Trevor Pordage
> thought he
> put into everything
> Trevor
> Brisbane Australia
unfortunately ken that parking brake was no longer in operation when i got the coach it had standard calipers on the rear wheels and all the parking
brake cable was gone the seat adjuster is still there . this is one of my problems as to register here i need a working park brake i am in the process
of converting the rear wheel set back to drums and Rob . M has brought a handbrake lever and front cable back from the states
Trevor
Brisbane Australia
Trevor,
You may want to consider keeping the seat adjuster to pull the parking
brake cable. That setup was a lot more effective than the hand lever when
Bobby had it working. I'm sure there are photos somewhere of that, or a
similar, setup if you can't figure out how it worked. That's assuming the
law down there only cares if it works, not how.
On Mon, Sep 4, 2017 at 3:27 PM, Trevor Pordage
> Trevor
> Brisbane Australia
"but frankly electromotive lost some key people and their tech support is lacking."
EMD? The fine folks who make Really Big gensets??? Electronmotive Division?
Not the same folks. These guys specialize in high performance engine controllers https://electromotive.com/contact-us/
> EMD? The fine folks who make Really Big gensets??? Electromotive Division?
> --johnny
1978 Royale-455
Navarre, FL
