Schrader Valves for Air Bags
vonda walsh
19
I tried to run a search, but couldn't find anything specific. Does anyone know where I can get replacement Schrader Valves for original style air
bags? Sean and Scott recommended replacing what is already there vs. upgrading just for the time being so we can properly diagnose the slow leak. I'm
already ordering the rebuild kit for the control panel because the dials spin and don't really lock in place.
> I'm already ordering the rebuild kit for the control panel because the dials spin and don't really lock in place.
Ace hardware among others. It is a standard gizmo.
http://www.gmcmhphotos.com/photos/data/5047/GMC_schrader_valve1.jpg
73 23' Sequoia 4 Sale
Upper Alabama
"Every day I become more convinced that I am the only person left on the planet that recognizes nonsense for what it is."
If you only are looking for a Schrader valve then get the ones A sent the
link to. If you need shut off and Schrader valves we sell them $85 for a
pair.
www.bdub.net/sully/
Sully
77 eleganza 2
seattle
On Wed, May 10, 2017 at 10:21 AM, Vonda Walsh
> leak. I'm
Vonda,
The schader and stop valve sets were never an OE part.
The "Schader" valve is just the valve like a tire valve stem. You might be able to buy those at a good hardware store, but they probably only have
them in 1/8MPT and you will want 1/4.
If you want the whole set, shut-off, T and schader, it is unlikely that you will find it locally. You can buy the kit from a GMC supplier or try to
pick all the parts out from the Mcmaster - Carr pages. That last is not recommended for anyone not very familiar with the parts.
ACE Hardware commonly carry them in both 1/8 NPT and 1/4 NPT.
They also carry the brass T fitting and I have seen the air shut off valves in my local ACE
but it probably is not carried in all ACE stores.
> Vonda,
> The Schrader and stop valve sets were never an OE part.
> The "Schrader" valve is just the valve like a tire valve stem. You might be able to buy those at a good hardware store, but they probably only have
> If you want the whole set, shut-off, T and Schrader, it is unlikely that you will find it locally. You can buy the kit from a GMC supplier or try to
> pick all the parts out from the McMaster - Carr pages. That last is not recommended for anyone not very familiar with the parts.
> Matt
Thank you everyone. I had another GMCer recommend trying teflon putty prior to replacement because he feels the shut off valves on my coach are higher
quality so it's likely a different issue. He also recommended I have the cores on the valves replaced prior to just replacing everything. I'm going to
give those two ideas a shot. If it doesn't work, then I'll go with the links you recommended.
My control panel is also in need of repair as the dials for the air compressor are very loose. I'm working on getting the rebuild kit for that too.
Thanks again!
76 Eleganza II
