ACE Hardware commonly carry them in both 1/8 NPT and 1/4 NPT.
They also carry the brass T fitting and I have seen the air shut off valves in my local ACE
but it probably is not carried in all ACE stores.
Emery Stora
>> I tried to run a search, but couldn't find anything specific. Does anyone know where I can get replacement Schrader Valves for original style air
>> bags? Sean and Scott recommended replacing what is already there vs. upgrading just for the time being so we can properly diagnose the slow leak.
>> I'm already ordering the rebuild kit for the control panel because the dials spin and don't really lock in place.
> Vonda,
> The Schrader and stop valve sets were never an OE part.
> The "Schrader" valve is just the valve like a tire valve stem. You might be able to buy those at a good hardware store, but they probably only have
> them in 1/8MPT and you will want 1/4.
> If you want the whole set, shut-off, T and Schrader, it is unlikely that you will find it locally. You can buy the kit from a GMC supplier or try to
> pick all the parts out from the McMaster - Carr pages. That last is not recommended for anyone not very familiar with the parts.
> Matt
> Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> Still Loving OE Rear Drum Brakes with Applied Control Arms
> SE Michigan - Twixt A2 and Detroit
