Sanity check on rear brakes
mark1
940
So, I did a brake/bearing service on the rear four wheels...
1) New 1-1/16" wheel cylinders on the middle bogies, one new 15/16" cylinder on the rears (the other one was fine)
2) New "Thermo quiet" brake shoes on all four wheels
3) Cleaned and re-packed all four wheel bearings
4) Cleaned and lubed (as much as possible) the parking brake cables - they were pretty sticky before, all seem to move OK now
5) Adjust the brakes by turning the adjusters to "really dang tight", then backing them off to where they're easy to spin by hand, and are obviously
"free" at at least one point in the rotation (they pass the "ring test").
6) Gravity bled the brakes - I'm sure I still need to do a good old-fashioned "real bleed", as the pedal is a little soft, but gets really stiff
before it hits the floor.
Took it out for a spin, and stopped after a couple miles of stop and go driving, and all the drums were warm, but none were really hot. Ran the coach
up and down the freeway a few miles, and did a few "both feet panic stops" from speed (~50mph, down to probably 30mph), and one or two 35-0 full
stops. All this was in the last 1/2 mile of driving.
Got it backed into the warehouse, and checked the temperatures of the drums. The two on the left side were nice and warm, but I could touch either of
them with my finger, lightly (no way I could leave my finger there though).
The two drums on the right were well over 212° based on the "spit sizzle test" (no fingers involved). The middle wheel drum was obviously hotter
than the rear wheel drum.
I jacked up the right side, and with a stiff push with my foot, the rear (cooler drum) wheel would rotate about 3 revolutions before stopping. The
front (hotter drum) went around 15 times. The bearings both feel good with just the tiniest bit of discernible play when you push/pull on the
wheels.
My guess is that the middle right drum is hotter because it's working better than the others, which I'm guessing might have something to do with less
contamination on the pads and drum during reassembly (it was the least fiddly of the bunch), and that the others will "come around" as they're used
and bed in. Or possibly, there is air in the lines on the other "cooler drum wheels"?
Anyone out there agree / disagree with my SWAG?
Mark Hickey
Mesa, AZ
1978 Royale Center Kitchen
> ... Or possibly, there is air in the lines on the other "cooler drum wheels"?
It seems to me that air anywhere from the combination valve rearward would make all 4 rears act the same. Seems to me there is an obstruction
somewhere. But I defer to others who know the system better, i.e. is there a line from the combination valve to each side or only one line feeding
both sides?
73 23' Sequoia 4 Sale
Upper Alabama
> obviously "free" at at least one point in the rotation (they pass the "ring test").
Mark,
Gravity Bleed is as good as anything else.
Pressure bleed is faster, but can blow past trapped air.
Vacuum bleed needs the screws sealed with pipe dope or teflon tape, but it is still faster than gravity bleeding.
If you left the self adjusters in, wait a few trips, then get rolling backwards in a big lot and jam the brakes a few times. They will then be
adjusted as well as they can ever be. Self adjusters do work if you keep them free and use them.
It just occurred to me that I should mention that the one wheel that's getting the hottest is the only one that "acted right" when I adjusted it -
that is, I snugged it up, then backed off the adjuster, and it spun free 360°.
All the others were dragging at least a little by the time the adjuster was backed off enough for them to "ring" at one point in a rotation (meaning
that the shoes were no longer contacting the drum). None were dragging enough to concern me, based on me being able to easily spin the wheels by hand
and get at least a couple rotations (that's not gonna be enough drag to generate any serious heat, IMHO). But would that also indicate that the shoes
/ drums have to "bed in" to get a perfect match between the surfaces, and that the braking might be compromised until that happens?
Mark Hickey
Mesa, AZ
> Matt
Yep, I left them in, and they seemed to be free and able to do their job. They all "ratcheted" when I was tightening the self-adjusters to center to
brakes, and had to be released to loosen them again. I did a few "full brake reverse stops", but only from 5mph or so. I'll do a few more of those
(in a MUCH bigger parking lot than I was using) and see if things get better.
Mark Hickey
Mesa, AZ
Yes, things got better. After every few reverse stops, the brakes got better. Soon enough, I was leaving skid marks (from the rear wheels, no
doubt), and the coach was stopping better than it ever did. Hooray.
I do want to take it out after the drums (finally!) cool down - the middle drums were near 300 degrees, and the rears about 220 degrees. That's after
quite a few hard stops, but with five miles or so of "normal driving" before taking the temperatures.
I believe this might be partly because of the parking brake. After the "self-adjusting session" in the parking lot, I could only pull the lever up a
couple inches. I had to unscrew the cap a LOT to get it adjusted properly (or as close to properly as these things get), but I did that after I got
back to the warehouse and measured the drum temperatures.
Mark Hickey
Mesa, AZ
Remember that drums expand quite a bit as they warm up. So, adjusting them
when hot might result in some dragging of the rear brakes when they are
completely cold. The idea is to have them right when at normal operating
temperature. The extremes just have to take care of themselves. What you
don't want, is to have the drums expand so much that you sacrifice some
braking effort. (Fade)
Many coach owners, myself included, never apply the parking brakes for
the reasons that you described. They don't always release completely and
the result is dragging brakes. Be careful locking up the rear tires, they
are easily flat spotted. The different sized wheel cylinders should help
some in that regard. The final solution would be the reaction arms. That
system really does work well.
78 GMC ROYALE 403
> a
> Mark Hickey
> Mesa, AZ
How are your return springs?
When they get heated the spring will loose the tension.
Throw them on a concreat floor and see if they bounce, if it sounds dud then replace them
You'll always have some friction
Sent from my iPhone
> dragging
Thanks, guys...
Good advice in both cases. I did the "parking lot backing up adjustment" with the drums at normal driving-down-the-road temperatures (very little
braking getting to the parking lot I used), so that should be OK.
And Jim, I just replaced the springs (and shoes) with parts I got from you, so they should be golden. The springs were certainly tough enough to
install that I'm pretty sure the tension is plenty good! ;)
The drums have cooled down, so I'm going to go for another test drive to make sure the drums aren't getting too hot "just driving along".
Mark Hickey
Mesa, AZ
Started the test drive with all the drums right around 100°. Did a few miles of (careful, slow) stop and go, and stopped to check them again. The
rear drums were around 115° and the rears 125° (I should mention it's in the high 90's outside today).
Also, the brake pedal seems good and stiff, so I'm going to forego any additional bleeding.
Seems good to me, so I'm going to call this one fixed and done.
Mark Hickey
Mesa, AZ
Mark,
make sure you have replaced the rubber hose, as they collapse and will not
let the fluid back out of the cylinders.
> Mark Hickey
> Mesa, AZ
Applied/GMC, Fremont,CA
Thanks, Jim... I'll be replacing those soon - they look "OK" but I know they can age out and cause problems. It seems that the brakes are (finally)
dialed in and working better than they ever have for now, so I'll be replacing those lines a little later.
Mark Hickey
Mesa, AZ
Great, the springs will look good, but the trick of dropping it on concrete
does work.
> Mark Hickey
> Mesa, AZ
