RV Outlets...
Matt Colie
11,101
807
113
South East Michigan near DTW
Steve,
If you only have a single breaker feed, you cannot actually support 50amp. Given that, I would not bother. We can get along fine on a TT30, and most
of the time we are happy with only 15.
You do know that a TT30 is not a NEMA standard, so be very careful if an electrician is involved.
> Hey Guys...
> Doing a bit of remodeling in my shop before winter hits...
> I have the opportunity to put a dedicated RV Circuit in... Do I need a 50 Amp or can I get buy with a 30 Amp... At the moment my GMC only has one
> roof AC but I MAY eventually put two up there...
> There is only a 60 AMP breaker serving to power the entire shop now BUT I plan to pull more power in next summer...
> Thanks for your input..
> Steve
less you plan on actually run both A/C's inside the shop, 30 amp will due you. Probably get by with standard outlet if you will just be charging the
batteries.
Tom, MS II
1975 GMC Avion
KA4CSG
