Got a lot of Dave's parts. But not his upper A arms. Bob Dunahugh 78 Royale
Sent: Monday, November 7, 2016 12:30 AM
Subject: Ruuing a higher ride highth then normal.
I need to run the rear frame height about 1 to 2 inches above the factory spec. I have the quad bag system. This system seems to be more stable. But also a little more course. Over all I'm very please with it's performance. But when you run above stock at the rear. You start to reduce your front negative caster. And we already have very little negative caster to start with. So I need to raise the front to match the rear extra height. So are there others that have done this?
