RPO numbers
patrick flowers
1,460
Ty,
Open your dash and release the catch that keeps the tray from going too
far forward. Hopefully you'll find a "build sticker" with a bunch of
codes on it. Then go to the VIN decoding page on my site at:
http://www.gmcmotorhome.com/faq/vin.html
Halfway down the page there's a bunch of codes which identify GM models
courtesy of our own Dave Greenberg. If this doesn't help, pull out the
rear cabinets(only if you gotta' know real bad) - I found a sheet
there which GM had sent to Gemini which positively identified my coach
as a CanyonLands.
Patrick
> Hi All,
> Well, I just can't stand not knowing anymore. I see most of you list your
> coaches by style or design i.e.. Painted Desert, Royale, etc... I pulled up
> some RPO numbers from GMCmotorhome.com but can't make heads or tails of them.
> I have no idea what type, style, or whatever it's called my GMC is. I really
> need some help here. As far as I can tell the original interior was a blue,
> the passenger seat is a two person bench (doesn't look factory) and the rear
> bed appears to have been redone so that's it's a permanent bed. It's a 26
> footer, side bath and a bench seat across from the dinette that converts into
> a bunk bed. I don't know if any of this helps but I would appreciate any help
> figuring out what type coach I've dug up and brought home.
> Thanks,
> Ty 73 GMC ??
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
Ty, Dave Greenberg can probably give you that information from your TZE
number. He and I will be off line for the next week. FMCA rally in
Brooksville, Fl.
JIm Bolick
'73 Painted Desert
Send the data to me -the RPOs as they appear on the glove box decal- and
I will try to decipher them for you.
Dave G.
> Hi All,
>list your
>pulled up
>of them.
>really
>blue,
>the rear
>26
>converts into
>any help
> Thanks,
> Ty 73 GMC ??
