my 78 Birchaven also has the 3 front battery setup - it appears that the
'original' setup was the:
the driver side battery and one of the passenger side are cabin
batteries - the remaining passenger side is the engine battery
the way to tell is to trace the cable going to the engine starter back
to the battery - it should go to one side of the boost relay then
directly to the battery
the other two batties will go to the other side of the boost relay by
one means or another
I reworked the configuration - the driver side battery is now a standard
lead acid - the hot lead goes from the battery across the top of the
radiator to the boost relay and then directly to the engine starter -
there is a post just above the booster relay that is labeled 'engine +'
that has leads for dash etc.
the two passenger side batteries are deep cycle marine - they are wired
in parallel - the hot leads go to the 'other' side of the boost relay -
a cable goes from there to the back of the cabin and the Onan - so there
are 3 heavy cables tied to the cabin side of the booster relay
now my installation is different here - my battery isolator failed so I
made temporary repairs that have become permanent - I took the
alternator lead off the center of the isolator and attached it to the
engine side of the boost relay - when I am mobile (or engine is running)
I set the boost switch in - this allows the alternator to charge the
cabin batteries - when engine is off i set boost off to isolate the
engine battery - it is a MANUAL operation so it is possible I will
'forget' and could run down all three batteries but in my situation I
very seldom use the cabin batteries for long periods of time without
having the Onan running
works for me
there was a comment a couple weeks ago about the boost switch not
working if the cabin batteries are too low - exactly right - the hot
lead on the booster relay comes from the cabin battery - the hot control
lead of the relay is just an inch from the engine battery post on the
relay - if the cabin batteries are too low to trigger the relay just
start the engine then use a small screwdriver to short from the relay
hot control post to the engine battery post - make sure that the engine
is running because the low house batteries will immediately draw lots of
current from the engine battery to balance out the three batteries - you
will hear the alternator pull down - if I am in that situation I usually
get the Onan running at that point and then switch the boost off - this
lets the Onan charge the cabin batteries and you can turn the engine off
after a couple minutes after it has a chance to bring the engine battery
back up to full charge
ron keener near Austin, Texas
http://MidAmericaBreedingTech.com
* proud owner of classic 1978 GMC Birchaven motorhome
