>I don't have any roof leaks that I know of but since we are planning
>on doing a good bit of GMCing this summer I wanted to make sure by
>sealing the suspect areas. Are the rails along the sides a problem
>area for leaks? Should they be sealed to the roof? If so with what
>type of material. Thanks in advance.
>Chris Taylor
>76 PB
>Rochester, MN
>________________________________________________________________________
>Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Some have had leaks with them but mine have never leaked. The end of
the rails where the front fiberglas cap meets the aluminum roof and
the sides (also on the back end) do sometimes have a problem. You
can remove the small cap that is fastened with one screw. Pull it
straight out as there is an aluminum insert that can break off of
you're not careful. You may need to put some sealant in the area
under this cap. There is a rather large hole there (1/2" dia or so)
where the panels meet. I used polyurethane sealant (Sikaflex) and it
has held for years.
The top rear corner of the driver's and passangers side windows are
also places where leaks tend to occur.
Santa Fe, NM
>Chris Taylor
>76 PB
>Rochester, MN
has held for years.
Santa Fe, NM
