I just used a stiff brush and some strong cleaner, AK 409 etc, looks way better.
Sent: Wednesday, March 1, 2017 2:43:35 PM
Subject: Re: [GMCnet] Roof cleaning
If the pressure washer lifts the sealant then it needs ti be replaced
anyway.
Sully
77 eleganza 2
Seattle
> G'day,
> As my signature notes I'm pedantic and would like to note that you should
> be
> careful if you use a high pressure water washer with the direction you
> point
> the nozzle at any point where there is a seam especially at the front and
> rear caps. The caps go over the aluminum so at the front direct the spray
> towards the rear and at the rear towards the front. If you don't do that
> you'll run the risk of driving water between the cap and roof.
> Regards,
> Rob M.
> The Pedantic Mechanic
> USAussie - Downunder
> AUS '75 Avion - The Blue Streak TZE365V100428
> USA '75 Avion - Double Trouble TZE365V100426
> USA '77 Kingsley - TZE 267V100808
> -----Original Message-----
> From: Gmclist [mailto:gmclist-bounces] On Behalf Of Todd
> Sullivan
> Sent: Thursday, March 2, 2017 7:08 AM
> To: gmclist
> As emery said. Pressure washer. Make sure you clean the area you plan on
> standing FIRST and i would do the sides of the roof where it curves from a
> ladder. The roof is fairly slippery whennit is clean and wet. Add a layer
> of wet mildew and it is downright dangerous. I have had the force of the
> water pressure pivot me all the way to my feet like a lazy susan when the
> gun trigger is pulled. Spooky.
> Sully
> 77 eleganza 2
> Seattle
> > Actually yours is a painted roof. First try a good car wash soap. If
> you
> > have access to a pressure washer that might help. Walmart and Home Depot
> > both sell heavy duty detergents for use with a power washer that won't
> > affect the paint. Some are specified for vehicles and boats.
> > You might one of those even if you don't have a power washer and they are
> > a heavy duty detergent. If you have mildew or grime on the roof you may
> > have to use a scrub brush with the detergent.
> > Emery Stora
> > 77 Kingsley
> > Frederick, CO
> > > I am getting ready to cleanup my new gmc as soon as weather warms up
> and
> > want to get my supplies ready, the coach has sat out in the elements for
> > > at least last 2 years without being cleaned so the roofs is black. Any
> > suggestions on products to use, everything I see is for rubber roofs
> while
> > ours are aluminium and smc .
> > > Terry
> > > 75 Glenbrook
> > > Dauphin, Manitoba
