Roof A/C
chuck blanford
296
I am also interested in the answer to this post. My compressor doesn't
kick in for several minutes, but seems to function well and stay on line
once it does.
Chuck
> From: Dave Lowry
> To: gmcmotorhome
> Subject: GMC: Roof A/C
> Date: Monday, August 17, 1998 2:02 PM
> Arch (or anyone else who might know);
> The recent post re: capacitors reminded me of another abnormality I have
> not yet dealt with. Whenever we start the roof a/c, the fan comes on
> immediately but the compressor doesn't kick in for 60 to 90 seconds. Once
> working, it cools well and has never failed, but I'm worried that one day
> it will. We're about to leave on a coast-to-coast-to-coast trip (7,000
mi.
> or so), and will certainly need the a/c to work.
> Is it likely to fail without further warning? How can I prevent failure,
or
> fix it when it fails?
> I can't get onto the roof to fix it myself, but I'd sure like to have an
> idea what was wrong before I had someone else get up there an play with
it
> at my expense.
> I travel with all the manuals (thanks to Cinnabar) and many useful snips
> from the posts on GMCnet, but I haven't found any mauals for the old a/c.
> Any ideas what's going on?
> TIA, Dave
> ps: I too look forward to the daily GMCnet e-mail. I wouldn't be keeping
> this beautiful but needy old girl were it not for all the information and
> assistance available here. Thanks all!
it will. We're about to leave on a coast-to-coast-to-coast trip (7,000 mi.
Is it likely to fail without further warning? How can I prevent failure, or
idea what was wrong before I had someone else get up there an play with it
at my expense.
TIA, Dave
If I'm not mistaken, the roof top A/C manual points out that there is a
delayed start for the compressor. I'm not at home now and don't have my
manual available to me to tell you the reason.
Paul Bartz
Sent: Monday, August 17, 1998 1:48 PM
Subject: Re: GMC: Roof A/C
once it does.
Chuck
Once
day
mi.
failure,
or
an
with
it
> at my expense.
snips
a/c.
> TIA, Dave
keeping
and
Dave,
Has this unit always behaved this way as long as you've owned it or did
it just start doing this recently. IIRC, the roof a/c on my father's
old HRC trailer also had a delayed start on the compressor. This was a
safety feature to prevent compressor damage if the power went out and
came back on quickly. It allowed refrigerant pressures to equalize
before the compressor restarted.
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Mine works the same way and at first I thought I would have to replace it.
It runs fine and appears to be designed to run that way.
>at my expense.
>TIA, Dave
Many of the a/c units deliberately start the fan and then the compressor about
a minute or two later. Mine work that way and I just wait a few minutes and
then the compressor comes. It may be that your's is the same.
regards Al Chernoff
> at my expense.
> TIA, Dave
Date: Mon, 17 Aug 1998 12:02:06 -0700
My 78 Kingsley works the same with the fan coming on and then the compressor
90 seconds latter. I think it is the way the system works. It allows the
fan to come up to speed and then compressor to reduce head pressure when it
cycles on and off. So you should be ok, and have a great trip.
Thank You
Tim Jones
timjones
