Risoline
jeanne penrod
174
[Admin Note - Jim, This one bounced as it was multipart, HTML
encoded. Set your Outlook address book for "plain text" only
for GMCnet. Thanks, Patrick]
As an alternative to Risalone you might try GM TOP ENGINE CLEANER
Pt availeable at any GM dealers parts dept.List price $5.94.
I have used with great results.
Directions
1.Run engine to normal temperature.
2.Remove air cleaner.
3.Increase engine speed and pour about 1/3 of cleaner through
carbureator throat fast,stalling engine.(DO NOT POUR CLEANER AFTER
STALL)
4.turn off ignition.
5.After 15 minutes start engine.
6.At flucuating speeds,SLOWLY pour balance of cleaner through carburetor
throat,rinsing out deposits from combustion area.
This will not delute oil in you crank case.It cleans and restores your
rings.valve train,and lifters.
By the way if you time this procedure with an out break of skeeters the
smoke,5,10,or 15 minutes depending on engine sludge,will git'mal!!!!!
Jim Penrod,Jus hangin out an bein cool in Lake Placid,F.L.A.
>I have used with great results. Jim
>>Wynn's Tuneup will free up rings and lifters. Just add it to the
>>oil. It will burn off in about 15-30 minutes and you can litterly hear
>>the engine smooth out. An ex-Wynn's man Wayne Newland
The above two products may work on a different principle... but let me
ask a couple of questions of the group.
I have used products like the above, and Wayne is right you can
hear a difference in a very short time as the solvent frees up whatever
parts are partially stuck. The thing I noticed is, the clattering comes
back more slowly but just as surely. Has anyone else noticed, that in a
few days the same clattering sound is back, and if another can of solvent
is added the clattering goes away again, for a few days. I have tried to
remove the suspended or dissolved sludge by changing the oil while it is
still quiet, but the results have been disappointing.
I would be interested in Jim's and Wayne's (or any other users) comments
on the return of the clattering.
Regards,
John 74 Glacier
Try adding a quart of ATF to the crank case. ATF is very
high detergent and will flush varnish out of the lifters. Leaving
it in till the next oil change causes no problem.
To:
Sent: Wednesday, August 11, 1999 9:18 PM
Subject: Re: GMC: Risoline
> Regards,
> John 74 Glacier
John
I sold Wynn's for almost 10 years to dealers and stations...I also had to go
back and see these same people on a regular basis. I never had a problem
with Tuneup (the professional formula). Believe me, if there had been
problems, these guys would have been all over me, because they would have had
to do their work all over again without being paid. Occasionally, some j...
would draw product, not put it in the customers car and take it home for his
own use. But, that's another story.
Wayne Newland F9300 75 Palm Beach
> Regards,
> John 74 Glacier
