Rick,
Any of the following filter will fit the onan.
Fram PH-28A of PH2870, Hasting 134, Lee LP-2131, Mopar -323, Motorcraft
FL-271, Purolator FCO-252 and I use the AutoZone Deutsch D484 and Most
are under $4. The Onan filter will cost you.
J.R. Wright
GMC GreatLakers
Michigan
> Rick,
> Thanks for the "heads up" on the oil filter
> adapter and bracket. I just looked and they appear to
> be dry. To be on the safe side I made sure they were
> still tight. You are right the setup is right from Walt
> Disney! I have basically the same engine in my garden
> tractor (Onan 22 HP) and so I am used to such things.
> I ran the engine with the cylinder head shroud
> off to see if I could detect oil coming from the low oil
> pressure switch. Sure enough, shortly after starting, drops
> started to came out of it about every few seconds. It
> sounds like, based on the other posts on this subject,
> that could have been the start of a real gusher if left alone.
> I am fortunate to have discovered it early on instead of
> after the fact.
> I'll go to the local Onan distributor on Friday
> to get the replacement part and some oil filters as I doubt
> I can get good substitutes at my auto parts store.
> Richard
> > While you're in there, double-check the nuts holding the oil filter
> > adaptor AND motor mount to the crankcase. Mine loosened up, causing a
> > sudden and massive oil leak out the blower outlet. I was sure it was the
> > front crankshaft seal (even bought a replacement seal), but it wasn't. Being
> > loose caused the gaskets to blow out, (filter adaptor to mount, mount to
> > crankcase). I cut new ones out of gasket paper, with a little gasket sealer
> > they're still holding 3 years later.
> > This is one Onan design which is NOT very reliable. The outer engine
> > mount is a piece of flat steel bar stock running vertically alongside the
> > crankcase, and attached to it by the same two studs and nuts that hold the
> > oil filter adaptor on. Oil under full pressure passes to and from the filter
> > via two holes drilled through the mounting strap. Mickey Mouse.
> > My .02, HTH.
> > Rick Staples
> > '75 Eleganza
> > Louisville, CO
