Ride height
dean hanson
256
Jim H; You said that out of 25 coaches, only two had the correct height.
How does one determine the correct height?
Dean C. Hanson 75Avion
P.O.Box 2096
Fremont, Ca. 94536
(510) 657-9600
Read the appropriate technical manual for your coach, and the specs for
your coach will be listed. The FRAME RAILS are the most accurate places to
check ride height. There are FACTORY PLACED OVAL HOLES in the rails
directly behind the front tires as well as behind the rear tires. Specs are
given plus or minus a dimension expressed in fractions of inches to either
the center of the slot or the top of the slot.
The bottom of the bogie box, grease zerk, or top of the wheel wells
is NOT, I repeat, NOT an accurate place to measure for wheel alignment
purposes. Variables abound.
Many bench racers here will tell you different things that work for
them, and are "just as good" as factory specs.
They are entitled to their opinions. I personally use factory
dimensions established by the engineers that built the coach. Never steered
me astray yet, but, I have only 40 years or so of experience, so I could
learn different, yet.
I am presently in Petaluma, California. It is my newly acquired
stepdaughters birthday, and am away from my manuals. That is why I did not
mention exact dimensions. Will be home next week. If you contact me offnet
then, I will be happy to explain in greater detail.
On Wed, Jul 24, 2019, 9:07 AM Dean Hanson via Gmclist <
> P.O.Box 2096
> Fremont, Ca. 94536
> (510) 657-9600
Dean,
The subject is covered in the back of the GMC owners manual. You can download if you don't have it.
Measuring it is easy, but a pain. In most 26s one of the rear references is hidden by the generator mount.
Adjusting the rear is a minor pain if it is stock because you have to fiddle with the little lever.
Adjusting the front is a major PITA because you need the tool to unload the jack screw. If you try to adjust it loaded, I am told it will strip.
Oh, and yes, it takes three tries to adjust anything.....
Front ride height to the top of the oval should be 13 1/8 inches +/- 1/4 inch.
Rear ride height to the top of the oval should be 11 11/16 inches +/- 1/4 inch.
Scott Nutter
installed MSD Atomic EFI
Houston, Texas
Ah yes, the fun begins, again. (Grin)
On Wed, Jul 24, 2019, 9:57 AM Scott Nutter via Gmclist <
> inch.
> inch.
> Scott Nutter
> Houston, Texas
What's a typical pressure reading at the appropriate ride height? I'm seeing about 80psi, seems high for a 40 year old rubber bag.
Todd Snyder, Buffalo NY
1976 Eleganza II
Your bag is not just rubber. It has layers of fabric in it.
My old bags and my new old stock bags both had about 80 to 90 psi at proper ride height
> 1976 Eleganza II
Weight distribution plays a role in basic initial ride height. Air bag
pressures can raise or lower the coach for purposes like draining waste
tanks or uneven campgrounds. Air pressure in late Royale 26 foot coaches
can be as much as 120 psi. in some instances. Usual travel ride height is
85-95 psi. Lighter coaches a bit less, heavy ones a bit more.
Also front ride height affects the rear.
On Wed, Jul 24, 2019, 11:54 AM Emery Stora via Gmclist <
> proper ride height
> Emery Stora
> > On Jul 24, 2019, at 12:48 PM, Todd Snyder via Gmclist <
> > 1976 Eleganza II
When I bring my scales to a rally we usually weight 20 to 25 coaches. We have done this at about 15 rallys (mostly GMCMI, Dixielanders, and Eastern
States). We have found about the same results. 2 or 3 out of the 20-25 are correct. Do not let this number bother you because people that have
their coaches setup correctly do not usually present them for weighing.
On ride height, I have a set of blocks (measuring sticks) made out of 2x4s and 1x2s cut the the correct length to slide under the frame in front and
rear. Also on the measuring sticks is a graduated scale so you can easily read how low they are. It is very rare to see one high unless they have
crippled their air system with schrader and shut off valves, or the wireless air system. Front ones are never high. The reason for two different
size measuring sticks is so you can not mistake which ones are front vs. rear. We take 4 guys each with a stick and as they pull in, measure their
heights. It takes longer to write the numbers down than it take to read the sticks 30-35 seconds total for all 4. Then we pull ahead and weigh
them.
I usually saw up a bunch of old 2x4s and 1x2s to the correct lengths and hand them out at rallies to people that want them. I do not have the length
numbers in front of me. They are written the measuring blocks that are stored, along with my scales, at the airport. This method is sure a lot
easier than measuring down frame From the frame holes.
My measuring sticks for beneath the frame are similar to Ken B's except
that they're notched: I cut the stick to the distance from the ground to
the proper height beneath the frame in the front. Then, I cut 1/2 the
width down to the height at the rear. The 2" or so difference means
there's no confusion about which area to use when. SInce I usually need
them when setting ride heights, I want them to stand alone, so most are
made from 4x4's. I don't haul them around.
Using the measuring sticks for beneath the frame rather than to measure
from the tops of the prescribed oval holes also has the advantage that they
can be used at the left rear where the Onan obscures the hole.
JWID,
On Thu, Jul 25, 2019 at 4:41 AM Ken Burton via Gmclist <
> different
> them.
> length
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
My measuring "sticks" are made of steel. Round bases which were drop outs
from some thick steel plate, about 5" in diameter, and vertical pieces
welded to their centers that are 3/4 x 3/4" square tubing. The rear ones
are cut to the length so they slide under the frame rails. They are stout
enough to support the coach at rear ride height.
The front ones are cut to the center of the slot, and stand beside the
frame.
At Rallies, we use a team and a person to record their findings.
Quick, simple. ACCURATE.
JIM HUPY
On Thu, Jul 25, 2019, 4:44 AM Ken Henderson via Gmclist <
> JWID,
> Ken H.
> Eastern
> 2x4s
> easily
> > different
> their
> > them.
> > length
> > Ken Burton - N9KB
> > 76 Palm Beach
> > Hebron, Indiana
Block owners - Great idea! If you have a chance, would you mind doing a
quick measurement for us? Otherwise its easy enough to do with a ruler and
subtraction when im near my coach. I'm one of those wireless system owners.
Setting height quickly after we load up tackles one of the disadvantages to
the wireless system. Same could be said for when we leave the camp site.
On Thu, Jul 25, 2019 at 9:09 AM James Hupy via Gmclist <
> frame.
> JIM HUPY
> Salem, Oregon
> they
> > JWID,
> > Ken H.
> We
> > Eastern
> 20-25
> have
> > 2x4s
> and
> > easily
> > > different
> vs.
> > their
> read
> weigh
> > > them.
> and
> > > length
> lot
> > > Ken Burton - N9KB
> > > 76 Palm Beach
> > > Hebron, Indiana
> > > GMCnet mailing list
I was working on a Raspberry Pi based ultrasonic height measurement system to augment my Wireless Air (so that I'd be able to check ride heights from inside the coach) - but haven't had time to get back to it... I had it measuring fairly accurately - but couldn't find a good mounting location under the coach.
Maybe some day...
Rob
Victoria, BC
Rob
What an incredibly cool project.
Dolph Santorine
DE AD0LF
Wheeling, West Virginia
Howell EFI/EBL , Reaction Arms, Manny Transmission
> Maybe some day...
> Rob
> Victoria, BC
Someone wanted to know the dimensions for measuring beneath the frame, so
I've posted a photo of the measuring block I carry to rallies with my
alignment jigs; the dimensions are marked on it:
http://www.gmcmhphotos.com/photos/ride-height-block/p66520-under-frame-ride-height-block.html
Americus, GA
www.gmcwipersetc.com
On Wed, Jul 24, 2019 at 12:57 PM Scott Nutter via Gmclist <
> inch.
> inch.
> Scott Nutter
> Houston, Texas
Rob,
How accurate is fairly accurate?
From: Gmclist on behalf of Adolph Santorine via Gmclist
Sent: Thursday, July 25, 2019 2:33 PM
To: Rob via Gmclist
Cc: Adolph Santorine
Subject: Re: [GMCnet] Ride height
Rob
Dolph Santorine
DE AD0LF
> Maybe some day...
> Rob
> Victoria, BC
8-7/16" and 9-3/4". Thanks Ken. Now, I do not have to go look it it up.
The reason I made mine 4 separate sticks was so at the rallies we could have 4 people doing concurrent measurements before weighing. Also I always
have scrap 2x4 cutoffs around. For someone at home the need for concurrent measurements probably would never come up and 2 of Colonel Ken's design
might be better. You are less likely to loose one.
This is how we put the inch scale on them. Walmart has this in the paint section:
https://www.michaels.com/3m-scotch-expressions-masking-tape-ruler/10410914.html
One other comment. The reason for 2x4 size rear block is so the 2x4's the can also be used for sitting the rear frame on while adjusting front ride
height. You only want to lock the rear frame height in place. So set the 2x4s vertical and drop the air until the frame just hits them and you are
done. You only need to support maybe 50 - 100 pounds per side to keep it from moving while adjusting the front. The rest of the rear weight is still
on the air suspension and tires.
Ken B.
> Ken H.
> Americus, GA
> > inch.
> > inch.
> > Scott Nutter
> > Houston, Texas
No need for an electronic way to measure ride height as the hysteresis in most GMC suspensions keeps it from changing all that much in use. Set your coach to proper ride height (block the rear at proper ride height, set the front and then drive the coach a few miles and recheck ride height front and rear until it is proper front and rear after your drive. Now, measure the air pressure in the rear air bags. When you are about to leave on a trip, put that much air in the rear bags and boogie on. You will find few coaches need anything more than that. KISS is very much your friend here.
Jerry
Jerry Work
Kerby, OR
It is either within factory allowable tolerances, or, it is not.
Jerry Work is absolutely right. The null zone is 5/8". Ride height
specs are plus or minus 1/4". Whaaat?
On Thu, Jul 25, 2019, 6:26 PM Gerald Work via Gmclist <
> Before getting worried about accuracy, look at the factory error band. It
> is wider on the control device (ride height sensor) than it is on the
> device being controlled (ride height). Hmmm
> Jerry Work
> Kerby, OR
> Message: 3
> Date: Thu, 25 Jul 2019 20:25:45 +0000
> From: Keith V
> To: Rob via Gmclist
> Message-ID:
> DM5PR02MB277979008E70CA210C4DDD2CA4C10
> Content-Type: text/plain; charset="us-ascii"
> Rob,
