Caster is increased by moving the upper control arm rear adjuster closer to
the frame of the coach. If the maximum adjustment has been used, then an
eccentric or offset bushing can be fitted into the rearmost arm of the
upper control arm.
Salem, OR
78 GMC Royale 403
On Wed, Sep 7, 2016 at 2:48 PM, D C _Mac_ Macdonald
wrote:
> Doesn't a lower rear increase caster which makes for more stable
> "tracking" of the coach?
> Mac Macdonald in OKC
> '76 ex P.B.
> Sent from my iPad
> > I also use 2x2 cut to length and measure from ground to bottom of frame.
> > On the 76 Eleganza the problem is the front height. it is too high by at
> least an inch on both sides- more so no the driver side.
> > The adjustment screws on the pork chop are as LOW as they will go. NO
> further lowering adjustment available.
> > How can I get the front lower?
> > I believe the torsion bars and pork chops came with the coach from the
> factory.
> > The dinette and seats as wells as the 2 original overhead cabinets are
> out of the coach so it may be 200-300 pounds light in front.
> > I wouldn't think that would make much difference.
> > I guess I could load a couple of sacks of feed in the front and see if
> it makes a difference.
> > Any suggestions?
> > Gene Barrow
> > Lake Almanor, Ca.
> > 1976 Palm Beach
upper control arm.
Salem, OR
78 GMC Royale 403
> '76 ex P.B.
> Sent from my iPad
> factory.
> > Any suggestions?
> > Gene Barrow
> > Lake Almanor, Ca.
> > 1976 Palm Beach
