Ride Height Controls
sandy wilson
98
How do I confirm that the ride height controls are working? I have a
system that holds well and I can raise and lower the suspension with no
problem. My factory service manual has very little info on this subject.
I would guess that disconnecting the connecting arm and moving it by
hand should tell the system to raise or lower. Does someone have info on
these controls on a website .
Regards, Gil.
Gil,
You are right, you do have a thousand questions, hey thats OK- this is the
place for the answers!
Drop your rear end by setting the controls to lower. After it is down,
select "travel" on the controls, the coach should come up to ride height.
The compressor should shut off when the height control valves get the coach
to proper height and the tank pressures up. If this happens, you are 100%.
Hope this helps,
Jim Bounds
>Regards, Gil.
Jim Bounds/Co-op Motor Works Orlando www.gmccoop.com
