Restoration: Getting the cap above the drivers seat to it's original color.
Bob Dunahugh
2,784
4
3
Originally the ABS plastic cap up front. And around the big rear window mat=
ched your sun visors, and the steel bracket that the rear view mirror mount=
s too. The cracks can be repaired using ABS plastic pipe adhesive. Not the =
PVC type. Masking tape, and a drop cloth will protect the surrounding area=
. Wash the area with just water. Unless you find sticky areas. Or products =
like Armor All have been applied. As some of these cleaning products will r=
eact to the finish coat. An automotive cleaner called Paint Prep, Wax/greas=
e remover is the best in all cases. SEM makes a spray can color that's call=
ed Sailcloth White #15603. To improve adhesion. SEM also has a produce call=
ed Sand Free #38363 as a primer. It's clear. I highly recommend Appling th=
e Sand Free. I also did all the plastic around all the windows that was w=
hite originally. To do all the ABS plastic. You'll need 2 cans of Sand Free=
, and 5 cans of the Sailcloth. Cost is about $18 a can around town. On line=
is in the $12 range. SEM also has colors that you can use to change the ot=
her plastics in your GMC like the dash area. Bob Dunahugh Member GMCMI.
