Restart a 403
Ken B
16,834
277
83
In the next few weeks I'm going to restart a GMC that has not run in 19 years. Other than changing the oil and filter and making sure the trans and
coolant are full, what else? Belts, hoses, etc. will be taken care of after I get it running first. I am also thinking about pulling plugs and
putting some oil in the cylinders.
I was thinking about pulling the distributor and running the oil pump with a drill. I have forgotten which way to turn it. I will check the advance
weights for proper operation before reinstalling. Initial start up will be from a gas can and not the tanks.
Anything else?
I would crank it a while to get the oil moving before getting gas to the
carburetor. An easy way to get all the parts moving under no load rather
than just running the oil pump.
> Anything else?
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
*John Phillips*
Pull the plugs and oil the cylinders.
Take a wrench to the crank and turn it through at least two revolutions. If you don't insure the engine is free you could damage something if it is
stuck. Ask me how I know how I got bent pushrods on mine. The starter has adequate torque to damage parts if they don't want to play well with
others.
Find #1 TDC and pulll the dist and run the oil pump.
Then spin it with the starter while the plugs are out.
TDC again and reinstall the distributor.
The above is what I should have done. Not too bad after all as I found other problems that required a rebuild.
This was on an engine that had been running two years prior to this and stored indoors.
Steve Southworth
Palmyra WI
Oil in the cylinders...what Steve said .
Mike in NS
https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail
Virus-free.
www.avast.com
On Wed, Oct 4, 2017 at 6:24 AM, Steve Southworth
> something if it is
> others.
> stored indoors.
> Steve Southworth
> Palmyra WI
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
Ken,
John Beaver and I have recovered 3 coaches over the past couple of years.
Two parked outdoors for over 20 years and one unknown but probably 10+. In
every case, we pulled the plugs and rotated the engine by hand. Then used
an add-on gas can (I now have an old-fashioned 5 gallon jerry can with a
mounted electric fuel pump to fit nicely on the front bumper) to feed at
least the initial start up.
We didn't rotate the oil pump, but probably should have. To refresh your
memory, it rotates CCW -- just check the plug wires vs the firing order.
We were VERY fortunate -- all 3 engines fired up easily, did and do run
great.
> Anything else?
Someone who knows olds engines specifically should chime in, but tI have encountered engines that wont develop oil psi without the distributor in
place so you need a specific tool or an old distibutoe with the gears ground off.
I like to use ATF in the cylinders as I think it penetrates better.
Regardong the belts and hoses, the smart play is to replace them now rather than gamble and end up doing it on the side of the road.
76 Glenbrook
Olds will not build oil pressure with Dist out. If the Dist that drives an oil pump comes out with a gear on the end there will be no oil pressure
with the dizzy out.
The idea of spinning the pump first is to make sure oil gets everywhere it can under pressure. I run mine until the drill motor gets too warm for
comfort.
Steve Southworth
Palmyra WI
Pulling plugs and turning crank by hand for a min of 2 full turns is highly recommended. I've had engines that had stuck valves from sitting. The engine turned over easily then thunk, it stopped. Turning by hand usually won't damage anything, doing it with a starter will bend or break parts.
On one engine with a stuck valve, i freed it up using lots of Kroil in each cylinder through the plug holes. After it had sat a while, I then bumped the stuck valve lightly by rocking the crank. I didn't know exactly which valve was stuck and wasn't in a situation to pull the engine apart at that moment. The kroil vapor must have been sufficient because the valve loosened up the next day. When I started the engine, I used a 10:1 oil mix for the first gallon, and reduced the ratio by half with each additional gallon. Lots of initial smoke, but the engine loosened right up and ran smoothly.
With a stuck valve that you loosen up, I wouldn't consider that engine being a reliable runner. The stuck valve is likely due to rust which will destroy the guides like lapping compound. I'd pull the heads for a refresh before putting it into service.
Les Burt
Montreal
'75 Eleganza 26'
> with the dizzy out.
> comfort.
> Steve Southworth
> Palmyra WI
Au Contraire, I drive Olds oil pumps with an old oil pump drive shaft with
a hex socket welded on the end. One end goes down the distributor bore, the
other into my cordless drill. All Olds engine distributors used in our
motorhomes turn counter clockwise when viewed from the top of the engine.
The oil pumps are self contained, and do quite well when turned with a
cordless drill with enough beans to turn them. If you are anal, rotate the
engine to uncover the oil passages along the crankshaft a few times while
you are prelubeing. If you are really, really anal, pull the rocker arm
covers and check that you do not have any stuck valves. They don't play
well with reciprocating pistons.
78 GMC ROYALE 403
> ground off.
> with the dizzy out.
> comfort.
> Steve Southworth
> Palmyra WI
None of this addresses the cam lobes and lifter faces. Cranking slowly is the worst thing as no oil gets slung from the crank up to those surfaces and
you are dry metal to metal. Using a drill on oil pump does not get that accomplished either unless it runs down from upper valve train on those
lifters allowing it. The best and easiest way is to buy several gallons of oil, fill it till it comes out the breather you removed, drain it, put 5
qts back in and go. Crazy, but beats wrecking cam.
ATF is basically kerosene with additives so you could use that.
> 76 Glenbrook
> and you are dry metal to metal. Using a drill on oil pump does not get that accomplished either unless it runs down from upper valve train on those
John,
While your fear is not unfounded, it is a very well thought. As it happens, a lot of the lubrication of the cam lobes (for a Detroit V engine) comes
from oil running down the cam followers (lifters/lash adjusters. The cam followers are always on a primary oil feed line. As it happens, in Olds
engines it has to go to the front of the crankcase and come back. That is not a lot different than many others. This is why I always required that
lube oil pressure on an new (I mean really new, like the prototypes of a new family) be maintained for at least two full minutes at pressure before
the engine was cranked. Trust me, the follower fit in the crankcase is not so good that it won't droll oil down to the cam, but it does take a while
to get there.
You can do this with the oil pump, but we usually used a primer which is nothing but an air over oil can and fittings to couple to the engine lube oil
gallery. We would put oil pressure on the engine for that two minutes and then always pull the engine through 2 (I really mean 2 - 720°) before
anything else was done.
The ABSOLUTE FIRST thing to do is put a camera in EACH cylinder to asses t=
he rust. Rent one if you have too. Or hire someone that has one. Oiling th=
e walls may cause the plugs to not fire. Instant start is extremely import=
ant. Our 78 Royale sat next to a corn field for 20 years to the month. Hatc=
hed a fuel can with an electric pump to the carb.. Turned the pump on to f=
ill the carb. Pulling the distributor to run the oil pump to get oil on the=
lobs is a waste of effort. NOT happening. Cam bearings will still have so=
me oil on them anyway. The cam lobes are lubed from spray from the crank. =
NOT the cam bearings. And the cranks not spinning. It's extremely important=
to not take a chance of not having the timing correct. With spark, and fre=
sh gas. It will start instantly. If the walls have rust on them. Pull it do=
wn. Or. Put oil on the walls. Start it up. Then are you going to trust that=
engine 400 miles from home. When I got my 403 started. Started just like =
I turned it off 5 mins before. Bob Dunahugh
I sprayed a small amount of marvel myster y oil into an engine than turn it
over with a socket. It works for me and it fired right off. It's still
working today. Sammy
