If you need a Transmission cooler, the installation of the cooler would be
easier if you could mount that in front of the radiator. I installed mine on
the frame member that runs across the front. It went on easy, but would have
been easier if I didn't have anything in the way.
al
> Pulled everything from in front of the 455 crank pulley and all the
> "bolt-ons". Gonna REPLACE 'em all -- including that pesky water pump --
> while I can get at them and keep the originals for absolute emergency,
> can't-get-em-anywhere else spares or turn 'em in for the core charge.
> Found the bottom of the steel rad frame GONE! Gotta fab another then
> slather PRO-15 on everything in sight so THAT doesn't happen again.
> Radiator's not all that good looking and I plan to replace or recore it.
> Any thoughts there?
> While I've got her front end off, does anyone who's been through this have
> any suggestions? You know, stuff you'd like to do if you could do it over
> again.
> Thanks
> Dick 75 PB in Atlanta
al
> Any thoughts there?
> again.
> Thanks
