John,
This 7" version is probably the most all-around versatile, but the 4"
version is sometimes needed for tight locations:
From bdub's link:
https://www.toolup.com/Vise-Grip-7lw-7-Locking-Wrench-7LW?CAWELAID=120204890000042684&CAGPSPN=pla&CAAGID=37806089434&CATCI=pla-449119078685&CATARGETID=120204890000508900&cadevice=c&gclid=CjwKCAiAsoviBRAoEiwATm8OYMJSG-i62pXxw7c7zHAJh7XXtJerCKouoVVvP50G_gX3zN4t4sRPQBoCVTAQAvD_BwE
https://www.google.com/search?q=nut+breaker+vice+grips&ie=utf-8&oe=utf-8&client=firefox-b-1
> On Fri, Jan 18, 2019, 6:43 PM John Phillips
> > Is there something special about Matt's Vice Grips, or will any old pair
> of
> > big Vice Grips work?
> > On Fri, Jan 18, 2019 at 5:16 PM Ken Henderson
> > > Matt,
> > > You failed to tell John about your magic Vice Grips! Those MIGHT save
> > him.
> > > Ken H.
> > > On Fri, Jan 18, 2019 at 7:22 PM Matt Colie
> > > > > I started to replace the right-center axle wheel cylinder. I found
> > the
> > > > > brake line fitting to the wheel cylinder had been rounded off. Do I
> > > need
> > > > to replace the brake line to get a new fitting? Is there enough line
> > > > > slack to cut the tubing and replace the fitting?
> > > > > *John Phillips*
> > > > John,
> > > > You don't have to, but there is not enough slack to pull the line and
> > > > re-flare it for the new nut. Just buy a new piece of line as it will
> > be
> > > > easier.
> > > > You are an e-mail reader without a sigfile so I don't know where you
> > are,
> > > > but if you are anyplace that iron rusts I have a suggestion that will
> > pay
> > > > off in the future. On ever wheel cylinder or caliper, pull the bleed
> > > > screw all the way out and put a wrap about one and an half turns of
> > > teflon
> > > > tape
> > > > on it. This way, when you go to use the bleeder again, it just might
> > > > unscrew. The teflon tape keeps the brake fluid (that assist
> corrosion)
> > > from
> > > > getting into the threads and the environmental moisture is also
> > excluded.
> > > > Then just be sure that all the brake bleeds have their caps and the
> > next
> > > > time you go to mess with the brakes, things will go much better.
> > > > I used to used a teflon pipe thread sealant, but the tape works
> better.
> > > > It would be an even better idea if it were mine. Chuck Boyd brought
> > > that up
> > > > years ago.
> > > > Matt
> > > > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> > > > Electronically Controlled Quiet Engine Cooling Fan
> > > > OE Rear Drum Brakes with Applied Control Arms
> > > > SE Michigan - Twixt A2 and Detroit
> > > > _______________________________________________
> > > > GMCnet mailing list
> > > > Unsubscribe or Change List Options:
> > > GMCnet mailing list
> > John Phillips
> > * Rancho Cordova, Ca*
> > *10 miles East of Sacramento*
> > *1975 Avion. *
