Virgil, come to think of it, there used to be a stack of automotive propane
tanks at Cherry City Recycling off of Cherry Avenue in Salem. Just off of
the Salem Parkway. I scrounge around in there once in a while for scrap
metals for projects. Worth a look see, or, perhaps you have a similar
facility near where you are in Lake Oswego.
> Virgil,
> From here in S. GA, I don't know anything about sources in your area, but
> perhaps my experience will give you a clue: When I rebuilt my '76
> Birchaven w/rear bath, I made allowance for the huge 19.3 gallon (IIRC)
> tank by rotating it to parallel the driver's side wall, then mounted
> captain's chairs where they'd lean back over that tall box. That worked
> well until SHE insisted on replacing the chairs with a sofa, which would be
> too high over the box. I was lucky to find, in an RV surplus store in
> Elkhart, IN, a 6 gallon horizontal ASME tank, by Manchester Tank (big
> source -- check Google), designed for use in a small RV, such as a Class
> B. That enabled me to reduce the sealed metal enclosure size to fit
> beneath the sofa.
> I'd have preferred to install removable tanks, but the Birchaven's rear
> bath and Onan eliminated all the tall-enough locations.
> Even that small tank has proven to be more than adequate (which I define as
> not needing refill before every trip); I refill it about every 6 months or
> less often. Using only the refrigerator and occasionally the water heater
> helps. We don't go to very cold places and usually have shore power so a
> little cube heater is adequate for us.
> Surely there are RV surplus stores in Oregon? Around Harrisburg, perhaps?
> Good luck -- perhaps you can get some ideas at:
http://www.gmcmhphotos.com/photos/g3055-our-x-birchaven.html (This is
> before the small tank was installed.)
> Ken H.
> > Message 2 from James Hupy
> > Jim H.
> > Where would I check to find DOT approved propane tanks? Or, do you have a
> > source here in the Portland, OR area. I am planning on installing a
> > catalytic furnace and either and on-demand or more efficient water
> heater -
> > will still keep the stove and refrigerator in my 76 Birchaven 455 w/rear
> > bath.
> > Am slowly getting the renovations completed - looking to instal foam
> > insulation after my ceiling and wall wiring upgrades.
> > Virgil
> > Lake Oswego, OR
